20B Rotary Engine
Old Aug 29, 2007 | 03:20 AM
Kiken_808's Avatar
20B Rotary Engine
I'm pretty sure there were a few threads in the past about this, but I'm kind of new to this site so I would like to ask anyways. Would it be too much trouble to install the 3 rotor 20B Twin Turbo engine into the RX8? I was interested in buying this engine since its $5000 (not too bad), but what would the downfalls be?
Is it more advantagous to buy a motor with pure engine power or is it better to turbocharge/supercharge the stock motor?
I'm at an automechanic school so installation is not a problem, but at my level should I even trust myself to work on the rotary engine or should I pay someone else to do it (even tho it may cost as much as the engine or turbocharger itself)?
Here's the site I went on to: 20B TT Rotary Engine
Thank you all for your feedback.
Old Aug 29, 2007 | 03:22 AM
tajabaho1's Avatar
Destroying Threads
this thread is about to get.....nasty
Old Aug 29, 2007 | 03:28 AM
8 Maniac's Avatar
Senior Member
You're underestimating the price quite abit... I believe that a few who have done the project, including fabricating all the parts they needed to, spent in the $20,000 range... It will cost you more than a turbo set up at least.. more power, but more expensive. Also, you might pass emissions with FI, but with 3-rotor I'm rather sure it's out of the question
Old Aug 29, 2007 | 03:38 AM
Kiken_808's Avatar
Damn $20,000, but yea it makes sense with all the other modifications that are needed to fit the engine in just right....
Old Aug 29, 2007 | 07:05 AM
DMRH's Avatar
Some things to remember about a 20B conversion is all the extra work you need to do to make it work properly.
You cant use the RX-8 box as it will snap like a twig. The diff will be at breaking point any time too
Engine management, additional cooling suspension upgrades and a whole lot more will all adversly effect your budget to the point where you will spend $20k without blinking an eye if you are going to do the job properly.
Half that can be spent on the 13B to get the same power with slightly less torque. Car remains balanced, less stressed & easier to run
Unless you are going hard core racing, leave the 20B engines in the Cosmo
REgards
Old Aug 29, 2007 | 10:10 AM
1.3L's Avatar
Originally Posted by Kiken_808
I
In the "List of parts included" JSA lists a "Cam Angle Sensor." Why would a rotary engine need that? Or, are they just throwing it in to make life interesting for the next owner (?) LOL!
1.3L
Old Aug 29, 2007 | 10:18 AM
NoPistonZ's Avatar
20BWannabe
To do it right...between 22K and 30K!!! Start here VVV
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/surgery-has-begun-120256/
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Sifu
Aug 30, 2015 10:51 PM
Supernaut6
Aug 11, 2015 07:28 PM
vssystemluba
Jul 19, 2015 04:16 PM
