Mazsport NGK plugs
Old Aug 28, 2007 | 01:55 PM
LionZoo's Avatar
road warrior
Mazsport NGK plugs
The Mazsport website is showing a set of platinum NGK plugs that they say is compatible with the RX-8 at a much cheaper cost compared to the standard OE plugs. Does anyone have any experience with them? Thanks.
The plugs are:
http://www.mazsport.net/shop/index.p...=40&prevstart=
Old Aug 28, 2007 | 02:14 PM
angeljoelv's Avatar
angeljoelv
If they are the one in the pics they areBUR9Eq and Bur7EQ you can get them locally for 6.99 each. I bought mine in NAPA autoparts, hell I bought a whol ebox for my 20b. But then again thats if they are the ones in the pic
Old Aug 28, 2007 | 04:09 PM
Those are Rx7 plugs. you can get them *cheaply* at ur local autoparts store.
The thing with these plugs is that they fail *faster* than the stock RX8 plugs. I have yet to try them but lots of people said these plugs gives them a couple more horse comprare to stock rx8 plugs.
Old Aug 28, 2007 | 04:56 PM
Old Rotor's Avatar
Most are getting 25k out of the cheaper plug and 35-50k out of the OEM. I remember when I would have to clean and adj gap every 4k on my earliest RX-2(back when there was a big build up of lead on them). I had a tech for Champion Spark plugs try some different plugs, N/C to me. The best plugs and I tried some of the exotic ones too were NGK for all my Rotary cars.
Old Aug 28, 2007 | 04:57 PM
mysql101's Avatar
I think most turbo people use them. they work fine.
just change the plugs once a year. It only takes about 20 mins.
Old Aug 28, 2007 | 05:07 PM
MontrealRocketeer's Avatar
They work very well. I use them in mine, On 12 psi boost, came back from Tampa (Mazsport) use them on track and still working good after 10K KM (montreal)... And let me told you, I've gave them some pressure !
Old Aug 28, 2007 | 05:22 PM
jskup1's Avatar
The Chief
Are any extra shims required to use these?
Old Aug 28, 2007 | 06:03 PM
staticlag's Avatar
The Professor
dont use them, they are the wrong size for th renesis chamber and will cause a bulge in the housing during repeated heating/cooling.
Also, on a N/A they cause misfires and lost horsepower.
stick with the stock plugs.
Old Aug 28, 2007 | 07:14 PM
Any recommandations ?
Old Aug 28, 2007 | 07:38 PM
Icemark's Avatar
The plugs are:
Those are platinum plugs... the factory spec for the the Reni is Iridium plugs.
The factory NGK plugs are available for $20 each here:
http://www.sparkplugs.com/results_ap...1&AAIA=1431319
Old Aug 31, 2007 | 04:26 PM
Well, cant say 7 plugs doesnt work. many people have it and its working just fine.
but for N/A, I would rather stick with stock plugs.
stock plugs wasnt made for boost applications.
RevMeHarder
Jun 1, 2026 02:30 PM
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
Forevermore
Sep 20, 2015 01:04 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
