9.5's in rear (hmm)
Old Aug 27, 2007 | 11:14 PM
[06']x8||'s Avatar
9.5's in rear (hmm)
so people are tellin me that 9.5's dont fit the wheel well so i was wondering if that was a myth or is it true.. if so anyway i can make it fit lol
Old Aug 27, 2007 | 11:15 PM
[06']x8||'s Avatar
btw, the rims are JSR 19'' rims
Old Aug 27, 2007 | 11:17 PM
NgoRX8's Avatar
they'll fit depending on offset.
Old Aug 27, 2007 | 11:19 PM
[06']x8||'s Avatar
offset is 35 which i dunno if thats for both .. not to smart with these things
Old Aug 27, 2007 | 11:26 PM
Easy_E1's Avatar
Stock is 18" x 8" width with a 50 offset. Check this thread,,,
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Aug 27, 2007 | 11:28 PM
[06']x8||'s Avatar
i dont know what it means...
inner clearance 4mm less?
outer position EXTEND an extra 34mm?
Old Aug 27, 2007 | 11:32 PM
NgoRX8's Avatar
u should be fine with the right size tires. probably 255/35/19. if anything the most you'd have to do is roll your rear fender a lil.
Old Aug 27, 2007 | 11:33 PM
[06']x8||'s Avatar
lol roll?
Old Aug 27, 2007 | 11:34 PM
[06']x8||'s Avatar
Honey Get Out The Sandpaper!
Old Aug 27, 2007 | 11:38 PM
Easy_E1's Avatar
You are adding 38mm to the width of the wheel. 4mm on the inside and 34mm on the outside.
It means the inside of the wheel will move inward 4mm and the outside of the wheel will move out 34mm.
This is compared to the stock rim.
So get out the digital caliper or tape measure and measure outside and inside from the rim lip and see if you have clearance.
Old Aug 27, 2007 | 11:42 PM
the big round metal thing that holds the tire sticks out about an inch and a third more...
does that help?
Old Aug 27, 2007 | 11:53 PM
[06']x8||'s Avatar
yessir so is that gunna be a problem o_0 lol
Old Aug 27, 2007 | 11:59 PM
Easy_E1's Avatar
Bring your car to me and I'll measure it for you.
Are you reading any of this?
Old Aug 28, 2007 | 12:30 AM
dee, dee, dee. clap.
Old Aug 28, 2007 | 01:26 AM
808RX8YEZIR's Avatar
i have 19.5 on the rear with a +35 offset and they fit with no rubbing, but if i lower it im gona have to roll or shave my fenders.
Old Aug 28, 2007 | 01:33 AM
[QUOTE=808RX8YEZIR;2031760]i have 19.5 on the rear with a +35 offset and they fit with no rubbing, but if i lower it im gona have to roll or shave my fenders.[/QUOTE
19.5 damn
photos...
Old Aug 28, 2007 | 10:13 AM
CosmosMpower's Avatar
1935 lbs. FTW!
I have run 17X9.5 with no issues and I know 18X9.5 or even 18X10 fits fairly easily.
Old Aug 28, 2007 | 12:25 PM
effie's Avatar
Nightmares be gone...!!!
i'm currently running on 18"x9.5 offset 43 rear on 265/35/18 Yokohama ADVAN NEOVA AD07 tyres with no problems whatsoever..... oh yeah.... ive got RE-Amemiya Lowered Springs fitted too.......
Old Aug 28, 2007 | 12:29 PM
[06']x8||'s Avatar
where do you live o_0
[06']x8||'s Avatar
lol i live in FL noway am i going to AZ
Old Aug 28, 2007 | 12:43 PM
WreakLoosE's Avatar
They Fit fine for me... 19x9.5 5Zigen Sport Engine. But it also depends on the offset you are doing. that is the most important part.
Old Aug 28, 2007 | 12:48 PM
WreakLoosE's Avatar
The first thing is the offset you use as well as the overall rim width. I use 275/30R19 tires in the rear no problems at all no fender rolling no rubbing nada, I have a set of 285/30R19 tires im gonna try as well.. That will be super close to the Strut thing in the rear.. but ima try it..
Old Aug 28, 2007 | 01:07 PM
altspace's Avatar
Eccentric Shafting
Simple answer. 18x9.5 with 35 offset will rub if your are lowered. Rolled fender will clear but inner wheel liner will not.
Old Aug 28, 2007 | 02:07 PM
too clueless to search, hmmmm ...
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
