Defi Gauges, Where do you route the sensors ?
Old Aug 27, 2007 | 03:03 PM
Just like the topic saids.
I just installed the Defi Control Unit (Thx StealthTL!)
Now Im trying to find a *path* where I can squeeze 3 sensor wires thru the firewall without drilling a hole thru it ...
For Water Temp, Oil Temp, and Oil Press.
I have all the wires and oil filter block, just cant find any clear path
Can Anybody guide me to the light ?
Old Aug 27, 2007 | 03:06 PM
StealthTL's Avatar
Metatron
Just follow the heater/a.c. hoses, dig a screwdriver thru the big rubber grommet.
....much easier from the engine side, easier still if you pull the washer bottle out.
S
Old Aug 27, 2007 | 03:10 PM
OOOO
Im going to check it out RIGHT NOW
Old Aug 27, 2007 | 03:29 PM
Im back
Well, my screwdriver probably too short or I got the wrong line.
I keep hitting walls, I probably did it wrong.
Im gonna keep digging ....
Old Aug 27, 2007 | 07:52 PM
BlueRenesis82's Avatar
Registered Tracker
I found a rubber plug in the firewall, used a hot soldering iron and burned a hole thru it, ran the wires right thru that
Old Aug 27, 2007 | 09:27 PM
Do you have a picture of the location ?
Im thinking my sensor will go 2 ways. Left side for Oil Press and Oil Temp, Right side for Water temp.
Old Aug 27, 2007 | 09:31 PM
Registered Tracker
mine both ran thru the same hole
Old Aug 27, 2007 | 10:15 PM
I will give it a shot tomorrow.
Might as well do a DIY for it. Cuz I think this will help lots of people. (Bro took my camera, god damn it)
Old Aug 28, 2007 | 08:25 AM
Registered Tracker
^ post pics once you are done
Old Aug 28, 2007 | 10:59 AM
Im Done :D
Spent another 3 hours on it. almost got myself killed in the process ...
Well, its working now.
Still waiting for my brother to come back with my camera.
Old Aug 28, 2007 | 11:07 AM
Registered Tracker
pics
Old Aug 28, 2007 | 11:14 AM
Dont worry man, I will post pics up :P
Old Aug 28, 2007 | 11:38 AM
RPIRX-8's Avatar
Apexing at Oak Tree
With my install, we ran all wires through a hole we drilled behind the windshield washer fluid resevoir. We placed a rubber grommet on the hole and its super stealth.
Old Aug 28, 2007 | 04:04 PM
I route them thru the Hood release cable hole. No drilling needed.
but it was a *BITCH* get the the last cable into the hole cuz with 3 already in place (the hood cable and 2 sensor cables), the hole was kinda tight. :P
I just got the Oil Temp and Oil Press running, will finish the water part later the weekend.
Old Sep 18, 2007 | 05:14 PM
forgot to post pics.
Oil Temp and Oil Press shown, Water temp coming soon (as soon as I get my new PUMP from Paul @ Mazmart )
The install looks kinda whack, I just use Epoxy to glue them on the dash. I will fix it up later.
Attached Thumbnails Defi Gauges, Where do you route the sensors ?-09112007180s.jpg   Defi Gauges, Where do you route the sensors ?-09102007179s.jpg
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
Stubbs
Sep 27, 2015 04:06 PM
