magikone69
08-25-2007, 10:41 AM
jus got the pipe and we put it in the same day....i searched and i have some of my issues resolved but i need help with the others.
i hade test/race/straight/watever pipes on previous cars and im well aware with the smell and the heat and all that...only thing i have a prob with this particular pipe is it sounds very raspy under half throttle accelerating in 1st and 2nd and slightly in 3rd gear... it isnt much so noticed outside the car as ive heard the car drive by me and ive driven next to to the car to listen to it. when inside the car the sound is almost annoying...at WOT its worse...almost makes me not want to drive hard anymore....is this normal or is there somethin i can do to atleast minimize it...once the car hits operating temperature it does get a little better but its still there. is this normal with rotary engines? never had this problem with other cars, or could it just be the pipe. its a B&B with resonator.
the other problem is the exhaust hanger on the pipe, it seems to be placed incorectly, it rubs against the underside if the car (the long piece that runs front to back where the drive shaft is) and the hanger is bent in a way where it wont really reach the gromet in any way. i thought i may have instaled the pipe wrong but i cant see any other way to do it as all the flanges lined up and are bolted in now, and there seems to be no way to rotate everything...my only sollution seems to be is to cut the hanger, the pipe seems to be installed solidly enough that a hanger might not be needed.
anyone have any pics of installed pipes so i can see if i may have done anything worng, any other advise.
btw the car feels very nice, low end seems to be a little less responsive but the mid and top feels a lot better. after the flywheel and spark plug/ignition change is put in i will dyno to see what everything has done:rolleyes:
exhaust flames FTW:spank:
