(update) Problem from Prgress front sway bar
[LEFT]I just finished my front progress sway bar yesterday.
Why after put this on, it has noise when I drive on the road.
The noise is sound like something is crash with sway bar. It's Pretty lound.
But when I check the car there are still have enough space for sway bar.
And the bar is look fine and everything are look fine. But the things is I cannot find out where cause the noise, but when I drive the noise is come from the sway bar.
Did anyone know this kind problem, or anyone have this kind problem before[/LEFT
[IMG]http://www2.snapfish.com/slideshow/AlbumID=172333810/PictureID=3754614828/a=104028903_104028903/t_=104028903[/IMG
If need the e-mail adress: atony3333@hotmail.com
Password: 33333333
Password: 33333333
If cannot see the picture, please try this one
http://www2.snapfish.com/photolibrary/t_=104028903
And if they need the E-mail adress and password,
Password: 33333333
Password: 33333333
did you apply grease generously? by generously i mean a lot more than what was provided by progress.
did you torque the bolts to spec?
Bushing Clamp 25.6-36.9 ft-lbs
End links 31.8-44.8 ft-lbs
i was just told for front swaybar never use the middle setting why i dont know but tomarrow i will be setting them to full stiff and see how that works out....... with stock endlinks B/S maybe but ill will see
If you have a knocking sound it's either because the bars were not installed properly or there is a problem somewhere else. They're just swaybars and they fit fine. You can use all the front or rear bar settings.
Jeesh, some people are so clueless ...
u dont have to be a smart ***............ i didnt install
xAgyex
Jun 3, 2026 03:47 PM
{FS/WTT} 04 Black Rx-8 TRACK AUTOX TIMEATTACK
Billy Marcial
Mar 1, 2018 06:50 AM
Solidtrance
22
Sep 4, 2015 12:47 PM
