I replaced all 4 coils and my MPG went up by almost 3!
Old Aug 23, 2007 | 05:40 PM
Neddie Seagoon's Avatar
I had a CEL a month ago and was told two of my coils were failing. I had all 4 replaced since doing so only added a $100 to the cost. Since installing the new coils my mileage has gone from an average of 17/17.5 miles per gallon to an average of 20.3!
My 04 when new was getting around 20 (if I am remebering correctly) then after all the flashes it dropped in to the 17's.
Hope this is useful.
Old Aug 23, 2007 | 06:12 PM
Old Rotor's Avatar
What were your symptoms of the coil failure? How many miles, hot or cold climate, etc.
Old Aug 23, 2007 | 08:38 PM
savedsol's Avatar
Carbonormous
Gotta join Mazda Motorsports. All it takes is doing two AutoX's a year. All four would have cost you $80.
Old Aug 24, 2007 | 12:25 PM
Nubo's Avatar
Lubricious
Lol, the coils are less expensive than the spark plugs
Old Aug 26, 2007 | 05:04 PM
yamajj's Avatar
unless you go to www.sparkplugs.com and buy the NGK plugs, they'll cost $19 each. if you get the denso plugs, it'll cost $35 each.
yamajj
Old Aug 28, 2007 | 04:12 PM
New Yorker's Avatar
I know there's a TSB regarding the coils. Here's my question: if my car is running normally, and I've never had a CEL, can I assume my coils are ok?
Old Aug 28, 2007 | 04:20 PM
ZoomZoomH's Avatar
Mulligan User
that's a good assumption i suppose
what's the old saying, 'if it ain't broke, don't fix it?'
Old Aug 28, 2007 | 04:21 PM
ZoomZoomH's Avatar
Mulligan User
and for the record my '04's coils are still fine, still averaging just under 19mpg in mixed driving, though I may replace the coils anyway when it's time to replace the plugs just as part of maintenance
delicious_dallan
Jan 17, 2020 09:17 AM
drebbrnator
Dec 27, 2018 07:02 PM
dohon
Aug 1, 2015 01:46 PM
CMRine04
Jul 29, 2015 02:07 PM
dbarber
Jul 25, 2015 01:34 PM
