What size tires?
Old Aug 20, 2007 | 08:38 AM
Minty Fresh's Avatar
Fresh to Death
Question What size tires?
So I think I've narrowed it down to what wheels I want to get....I just need help figuring out what size tires would be best. (I want to keep my speedo changing any if at all possible)
Here are the wheels I'm looking at getting...
http://www.discounttire.com/dtcs/fin...9753&tc=PRVNET
Privat Netz
19X8 5-114.3 30FRG (65065)
Thanks for any help guys...
Old Aug 20, 2007 | 08:39 AM
StealthTL's Avatar
Metatron
Try the calculator at TireRack, one of the site vendors.....
S
Old Aug 20, 2007 | 09:19 AM
dbright007's Avatar
Book em' Dano
Ditto on the calculator.
Miata.net has a good calculator also.
http://www.miata.net/garage/tirecalc.html
If you are going to a 19" wheel, to minimize speedo inaccuracy you have to drop down to a 35 side wall. Little low for my liking. 245/40 would look good, and your accuracy won't be off too bad.
Old Aug 20, 2007 | 11:26 AM
RA-Eight's Avatar
Scuderia
Best bet is 225/40-19. Your speedo will be 0.426% too slow.
Old Aug 20, 2007 | 11:36 AM
NgoRX8's Avatar
245/40 on a 19 would be wayyyyyy toooo off...
you'll need to go either 245/35/19 or 255/35/19.
245 will make your speedo read faster than you are and 255 the opposite. those are the closest you can get to match the speedometer.
Old Aug 20, 2007 | 11:41 AM
NgoRX8's Avatar
but if the offset is 30 like in the link... then you'll either have to go with what RA-Eight said or a 245/35 like i said (which will rubb a lil)
Old Aug 20, 2007 | 04:08 PM
GRGJTSN's Avatar
vV Me on the Dragon Vv
225/40/19 is closest like RA-Eight said, but it is kind of an odd size and hard to find, at least in any variety. I remember when I was searching, I would have bought a 225/40/19 but cold only find one brand in that size, and it was too much $$.
255/35/19 is too wide for an 8" wheel.
245/35/19 is your best bet. That's what I went with, and reccommend.
Old Aug 20, 2007 | 11:09 PM
Fresh to Death
Thanks for the help guys.
The more I think about it....I think I might stick with 18's. Not just because of the speedo, but for other reasons. I think 18's still look good. Plus I'll have a few more options as well. This will also make tire choices easier I think. Back to the decision process. LOL
Old Aug 21, 2007 | 10:26 PM
rotorhead335's Avatar
Question size
Interesting. I have been thinking of going to 17", 235-40-17 or 245-40-17 (or even 45s in either size, if that's better, i.e., 235-45-17, etc.). Will this work?
Related Q: Does the offset need to change when rim/tire size changes?
Thanks,
Jeffrey
PS: BTW, is there a definitive size, other than the original fitment, that is thought to work best for handling, cornering, turn-in and such?
Old Aug 21, 2007 | 10:30 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Damn that frickin bug! Gets me almost every time!
Old Aug 21, 2007 | 10:55 PM
Thumbs up size matters
Would 245-35-18 or 245-40-18 also work well?
Thanks,
JT
Old Aug 23, 2007 | 11:37 PM
DavidSr's Avatar
Thanks,
JT
I have been running 245x35x18's for over a year now and they work fine. The only thing with me is I think 245x45x18's would look better. They will fill the wheel well a bit better. Not sure if they will rub in the front though.
On another matter: I keep getting a tire pressure light on the dash. It began last week. I run 40 lbs. of pressure and I know low pressure is not the problem. It seems that the light will begin to flash after the car gets good and warm. The flashing light will go off if I restart the car. Then after a while the light will begin flashing again.
Anybody else had this problem. If so, what can be done??
yurcivicsux
192
Sep 12, 2017 10:54 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
