Stick shift parking
Old Aug 19, 2007 | 01:22 AM
ashwins's Avatar
Question Stick shift parking
Hi,
I recently bought stick shift Mazda RX-8. I tried parking it in gear without using hand brake on a slope. The car was kind of shaking continuosly. However when I used parking brake, this sympton seemed to disappear.
1)Is there a problem if you park a car in gear without applying hand brakes on a slope?
2) Does rx-8 require frequent ignition coil replacements?
Old Aug 19, 2007 | 03:23 AM
636's Avatar
636
Rice Police
Wait...you're PARKING on a slope without hand brake? Wtf....did i just read that correctly lol. You should probably use the hand brake , kinda the reason its there. Correct me if im wrong , i read through the post pretty quickly.
Old Aug 19, 2007 | 10:13 AM
StewC625's Avatar
Insanely Yellow
ALWAYS use the handbrake on this car. Always. The rotary, when turned off, doesn't have the "locking" power from the reciprocating pistons like an ordinary piston engine. The weight of the car can easily over come the compression and spin the engine if you're on a steep enough slope.
Just use the handbrake - as 636 said, it's why it's there. It's called a "Parking Brake" for that reason.
Old Aug 19, 2007 | 10:16 AM
TimzSI's Avatar
Why would you NOT use the hand brake???? Anytime you park you must engage the hand/parking brake! Second gear + hand brake = peace of mind!
Old Aug 19, 2007 | 10:41 AM
ashwins's Avatar
Smile Thanks Stew!
I had driven in another country for a couple of years, and I had a piston engine car, and I was never told there to use parking brakes. I didnt know that rotary engines couldnt lock the cars as easily as piston engines could do when you engage the car in gear!
Old Aug 19, 2007 | 10:48 AM
RazzyBRX-8's Avatar
Representin'!
Even if I'm parked on a perfectly level surface, it's always in first gear with the parking break on.
Old Aug 19, 2007 | 11:13 AM
ashwins's Avatar
Question Cranks longer?
My RX8 has run for about 45K miles now. The Cranking on RX8 seems a bit long. I dont know if rotary engines have a longer crank time? I am suspecting the ignition coil is becoming weaker?
Old Aug 19, 2007 | 11:14 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
possibly.....or battery............anybody else?
Old Aug 19, 2007 | 11:32 AM
TeeFar's Avatar
Yup, I had the same problem. They replaced my battery and starter(recall I think) problem solved.
Old Aug 19, 2007 | 11:59 AM
NgoRX8's Avatar
yea, most likely the starter.
Old Aug 19, 2007 | 12:13 PM
ken-x8's Avatar
Where were you a few months ago when I got flamed for saying I used the parking brake but didn't put it in gear?
Good info about the rotary not really holding the way boing-boing engines do.
I've never been a fan of using a manual transmission as a parking brake. Always felt like holstering a cocked gun. I've never had a parking brake fail.
Ashwins - if you park on a hill, make sure you turn your wheels the proper way. Toward the curb if pointed downhill, away if pointed uphill. That's a legal requirement in a lot of places.
Ken
Old Aug 19, 2007 | 02:39 PM
ashwins's Avatar
Question Bose speaker system - 6 CD changer?
OK. My RX8 is a 2005 touring model with BOSE speaker system. I am not able to figure out how to insert multiple CDs in the system? Any suggestions?
Old Aug 19, 2007 | 03:41 PM
Ike's Avatar
Ike
Blue By You
Hi,
Are you a big David Carradine fan? Always park with hand brake grasshoppa, especially on slope.
Old Aug 19, 2007 | 03:44 PM
Rhawb's Avatar
Has the whole shit.
You need the six CD changer option. If you press the "load" button and nothing happens, you don't have it.
Old Dec 2, 2007 | 01:58 PM
coastie08's Avatar
In the manual it states not to use the parking brake in freezing temperatures as it could freeze (it also says to block the rear wheels). Currently I have my car in 1st gear parked on a flat surface without the parking brake because the temps have been below freezing lately.
Old Dec 2, 2007 | 02:10 PM
Ike's Avatar
Ike
Blue By You
That has been said about handbrakes for years... Yes it can happen. However I've owned excluisively MTs for the last 17 years and have always parked with the handbrake in cold weather without an issue.
Old Dec 2, 2007 | 02:21 PM
thisllub's Avatar
Why would you park your car somewhere that cold?
Old Dec 2, 2007 | 03:17 PM
coastie08's Avatar
thanks Ike, that was the response I was looking for
... I just went outside and engaged the parking brake.
Old Dec 2, 2007 | 03:21 PM
YaXMaNGTO's Avatar
It's a Cavalier
Reading this thread is like a lightning round of n00b jeopardy.
Old Dec 2, 2007 | 05:03 PM
ToothFairy's Avatar
girls have sticks too
When I had my first Rx8, I parked it on a hill with the E-brake on but not in gear
...Unfortunately the E-brake didn't hold.
Old Dec 2, 2007 | 05:11 PM
Mazurfer's Avatar
Actually if I'm on a slope, then it has always been in gear with parking brake applied and wheels turned the way they should be.....whether piston or rotory!!!
If I'm flat level, then it's just parking brake.
That was funny about the Noob jeopardy! (ha ha)
Old Dec 2, 2007 | 05:23 PM
RedSheDevil's Avatar
.:. causing mischief
I'll take The Rapists for $200 Trebeck!
Old Dec 2, 2007 | 05:26 PM
Mazurfer's Avatar
Hilarious!
I like the one with Sean Connery when he says......"I'll take Swords for $200 Alex", when it's S-words. So freakin funny!
Old Dec 2, 2007 | 07:04 PM
delhi's Avatar
Grand Chancellor
don't forget to orient the front wheels in accordance to the slope.
Old Dec 2, 2007 | 07:11 PM
Spinning Sushi's Avatar
I <3 Sushi
LOL! This thread wins.
