does anyone know where and how to reach the fuel filter?
Old Aug 18, 2007 | 02:19 PM
davidwanj's Avatar
does anyone know where and how to reach the fuel filter? any info would be nice, thx
Old Aug 18, 2007 | 02:42 PM
StealthTL's Avatar
Metatron
Cool
Sock type filter around the in-tank fuel pump assembly, and a felt pad type INSIDE the pump - no other filter.....
To reach -
lift up passenger side seat bottom and remove,
unscrew phillips screws on cover plate,
bleed off pressure at connector near master cylinder,
undo hoses,
undo electrical connector,
unscrew plastic pump top ring (mazda has a tool)
lift out whole pump assembly.
S
Old Aug 20, 2007 | 04:05 AM
chickenwafer's Avatar
Nope
and remember- your car will smell like gas for days
Old Aug 20, 2007 | 03:30 PM
DOMINION's Avatar
I don't buy Kool-Aid
Why would you need to get to it? Are you replacing it?
Old Aug 20, 2007 | 05:19 PM
CnnmnSchnpps's Avatar
No means yes
Oh cool! I always assumed you had to drop the gas tank...
Curious also as to why you need to get to it?
Old Aug 20, 2007 | 08:43 PM
davidwanj's Avatar
on the workshop manual it said "replace fuel filter every 37500 miles"....so I went to a mazda dealership where my friend's friend is the owner of the place....he said rx8 do not have a fuel filter...only thing you can do is replace the whole pump, he said they probably copy and paste that manual from the rx7 workbook
Old Aug 21, 2007 | 11:02 PM
Nope
it's not 37500 miles, it's 100,000 miles.
airlive
Jun 28, 2020 07:46 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
