More Problems here in Tucson
Old Aug 15, 2007 | 08:43 PM
bigsandman's Avatar
SouthAZ8
Hey guys....well some of you know I bought my 2004 MT about a month ago, and I have had this horrible oil leak......well its at the dealer again being looked at....the first time they changed the oil and said all is ok....but the engine has been smoking and dropping oil all over the fukin place....what do you guys think it is? does the engine just need to be replaced?
Old Aug 15, 2007 | 10:35 PM
Georgia8er's Avatar
You need to know where the oil is coming from. An oil change isn't going to solve a leak, but the engine would puke it back out the dipstick if it had been overfilled.
Old Aug 15, 2007 | 11:09 PM
MazdaManiac's Avatar
Check the oil filter seat for a left-over filter gasket.
Check the oil cooler plumbing for a missing fitting pin.
Look at the mating surface of the pan for a leak and the pan itself for a dent or crack.
Check that the dipstick tube is fully seated and the o-ring is intact.
Old Aug 16, 2007 | 01:53 PM
bigsandman's Avatar
SouthAZ8
thanks guys....well the smoke was coming from under the hood...and it always smells like oils is burning...and its dropping oil all over the place man....and yea it seems like it was overfilled...and i never put a drop in it....i dont fukin know i really want a new motor...
Old Aug 16, 2007 | 02:06 PM
Georgia8er's Avatar
The dealership hasn't told you what the problem was?
Old Aug 16, 2007 | 04:24 PM
bigsandman's Avatar
SouthAZ8
ok guys i drove over there to get the face to face situation....ok it turns out the oil pan gasket and the main seal are all fuked......so do you guys think this engine is even salvagable now? or will they replace my engine...because i guarantee i have a problem with compression now.....they said for sure it will be another few days......
Old Aug 16, 2007 | 04:42 PM
Losing oil like that won't lower your compression unless you ran it completely dry.
The real question is - what did you run over to beat the pan in?
Old Aug 16, 2007 | 07:18 PM
Georgia8er's Avatar
Must have been big to get the main seal too!
Old Aug 16, 2007 | 08:05 PM
Marietta 8's Avatar
We've seen 2 occasions where replacement engines did not get the rear stationary gear o-ring installed causing big oil leaks. last one was a reman renesis, prior to that it was a reman 13B-REW. Sloppy either way.
Old Aug 16, 2007 | 08:16 PM
Might have jacked the tranny on the way out.
Typical Williams Tech build quality.
Old Aug 16, 2007 | 08:36 PM
Georgia8er's Avatar
Since I don't know on a rotary, what about the front mainseal? I assume it has one.
Old Aug 16, 2007 | 09:38 PM
The front seal doesn't see serious load, but there have been some failures around here. Seems to be mostly on vehicles with aftermarket pulleys.
Old Aug 17, 2007 | 04:25 PM
bigsandman's Avatar
SouthAZ8
ok guys i got the full lowdown now!
my car has already had 2 reman's replaced...this is the 3rd motor...and yea the mail seal is totally fuked...they ordered the part and it will be in on monday..and my car out on tuesday...they said i have to return the rental car today.....i think that is bs since its not my fault they didnt get my car looked at until the 3rd day it was in!
Old Aug 17, 2007 | 04:31 PM
StealthTL's Avatar
Metatron
Gotta get that mail seal fixed or your cookies will fall out!
"Looks like you blew a seal"....NO! It's just ice cream!
....oh, that's baaad.
S
Old Aug 23, 2007 | 12:23 PM
JohnnyBGood's Avatar
JohnnyBGood
I took my 2004 RX-8 to Jim Click because it was stalling and loosing power in hot weather. Sure enough they said they were replacing the engine. Lucky my warranty expires in 4 months. And get this, the rental car loaner company said they have had many RX-8 rentals for 30 days or "engine replacement". So were's the recall? Sounds like a defect in the design to me.
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
