245/40R18 on stock wheels?
Old Aug 15, 2007 | 01:56 PM
titaniumgr3y's Avatar
JDM-8
Question 245/40R18 on stock wheels?
guys, i have been thinking to change my tires but i couldnt find 225/45R18 localy.
A friend of mine installed 245/40R18 on stock wheels and he says that everything is ok.
What is your opinion? any difference in height?
Old Aug 15, 2007 | 01:57 PM
I have 245/40/18 and they look and fell GREAT on my car.
I can post some pics if you want. (I'm sporting Kumho MX's)
Old Aug 15, 2007 | 02:11 PM
GrimRazor's Avatar
Thumbs up
I run 245/40 on stock 18" rims. IMHO the tire is an excellant size for a spirited driver. I dno't know what tires you are planning on buying but I run Nitto 555 and am very pleased with them. And btw the 245/40 is the same diameter as the stock setup there should be no change in your speed-o readings.
Old Aug 15, 2007 | 03:09 PM
Old Rotor's Avatar
Yes the 245X40's are the perfect upgrade, do it. I have the Bridgestone Potensa RE750. They are rated excellent. Costco save me hundreds.
Old Aug 16, 2007 | 12:54 AM
JDM-8
very nice... thanks guys...
actually i am thinking between continental and yokohama. high performance summer conditions.
Old Aug 16, 2007 | 01:23 AM
Cody Red's Avatar
always filling [the c]up
runnin' 40's here as well, auto-xing with them as well.
Old Aug 16, 2007 | 01:35 AM
http://www.1010tires.com/tech.asp
lots of cool info here
Old Aug 16, 2007 | 01:40 AM
Cody Red's Avatar
still didn't tell me what's the max width tire you can go with any wheel
Old Aug 16, 2007 | 01:43 AM
onephatguy's Avatar
18 month shelf life
I believe the difference is .3 of an inch in tire heighth. Just slightly shorter than stock. Should be fine. I'm glad some are running that width, I was thinking of doing the same. Any of you have it lowered with the 245/40/18? Any rub?
Old Aug 16, 2007 | 01:49 AM
nope,
it is not the oracle it is just good learning stuff...
Cody Red's Avatar
nope,
pm sent.
Old Aug 16, 2007 | 02:52 AM
depends on the tire..
i am lowered and dont rub... not even close...
offset is the key...
Old Aug 16, 2007 | 06:46 AM
JDM-8
i would love to lower my car's height but the roads in Cyprus even if they are very good they are under constructions most of the times :P
so, its better to keep stock height for the safe of my back and my suspension.
i ve even thought to put 245/45R18 to have a smoother/softer feeling and then lower it with springs so i will stay at the same height but it will look prettier and it will still be smooth.
Old Aug 16, 2007 | 09:10 AM
Elara's Avatar
About to put my second set in this size on the stock rims.
Old Aug 16, 2007 | 10:37 AM
puch96's Avatar
How could the 245/40 be the same diameter as 225/45 ???
if the 40 and 45 are the aspect ratio ratings (percentage of tire width), then
40% of 245 does not equal 45% of 225????
Old Aug 16, 2007 | 10:48 AM
StealthTL's Avatar
Metatron
Close enough, same size to a tenth of an inch, wider, cheaper, more widely available, and will actually make the speedo closer to accurate - where is the downside?
Use the calculator, Luke.....
http://www.miata.net/garage/tirecalcold.html
S
Old Aug 16, 2007 | 02:06 PM
bulletproof21's Avatar
^ all good points but there are not cheaper. Well the Kumho's are not cheaper. I just bout 4 new tires last week. The 245/40's were $30 MORE per tire than the 225/45's.
Old Aug 16, 2007 | 08:21 PM
StewC625's Avatar
Insanely Yellow
That's the size on my car. Height difference is negligible - it will increase speedo error by about 1 mph - from the factory, compared to my portable GPS, the factory speedo was off by 1.5 at 60, and when I switched the tires that increased to 2.3 mph error. Other than that, perfect.
I run Pirelli PZeroNero M+S from TireRack. They were great to work with and had an authorized installer local to me. I'm about to order another set in the next week or so.
Stew
Old Aug 16, 2007 | 09:07 PM
savedsol's Avatar
Carbonormous
Lowered with Mazdaspeed. 245/40/18 Bridgestone RE-01R. Fan-f'n-tastic!
Old Aug 16, 2007 | 09:55 PM
AlexCisneros's Avatar
I'm just amazed no one yelled "use the search button!"
Old Aug 17, 2007 | 01:16 AM
naw this guy is really trying to learn.. and does go where pointed...
Old Aug 17, 2007 | 01:25 AM
LabDad's Avatar
Doggie Style :)
*lol* I was thinking the same thing. We might be entering an era of the kinder/gentler RX-8 Club.
Old Aug 17, 2007 | 06:40 AM
savedsol's Avatar
Carbonormous
Numbers are a little more difficult to search for. 245/40 18, 245/40/18, 245-40-18, etc.
Old Aug 17, 2007 | 06:55 AM
Mugatu's Avatar
Even My Dog Searches
i shall allow this thread.
Old Aug 17, 2007 | 06:58 AM
wow,
roflmao,,,,,
houston, we dont have a problem...
all is well..
