connector identification (under dash)
Old Aug 12, 2007 | 06:27 PM
SportCoupe2's Avatar
I just picked up a '04 RX8 and upon a complete inspection I found a connector disconnected and the two wires are jumpered together with a piece of wire. I found where it connects to but cannot figure out what it is for and why it's jumpered. The switch it connects to is under the dash on the clutch pedal linkage. I added a pcture because that make it easy to visualize.
Old Aug 12, 2007 | 06:43 PM
Does the car have a remote start..thats the clutch switch that tells the PCM the clutch is depressed...........
remove the jumper...and plug it in
expo1's Avatar
He's as bad as Can
I bet your car will start without you pressing the clutch. That is the starter interlock switch. The only reason I can think the previous owner would do that would be to install a remote starter.
Old Aug 12, 2007 | 07:16 PM
I think you might be on to something. I just went outside and it did start without pushing the clutch in. I removed the jumper and connected the plug. Now it won't start unless the clutch is depressed, just like it's supposed to be......
I think we just avoided a disaster if the wife tried to drive it. Thanks members!
Shankapotamus3
Mar 14, 2021 03:53 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Quiggs321
Sep 30, 2015 05:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
