greddy turbo kit help!
Old Aug 11, 2007 | 09:26 PM
bmxer's Avatar
i installed the greddy turbo kit on a 06 rx-8, i am having trouble with the vacuum lines. on the instructions it says to hook up the jet fuel mix line to the charge pipe, and replace the oil bypass hose on the oil filler to the intake pipe, and the metering oil pump to the intake pipe. what happens to the hose that was originally on the oil bypass? and which hose is the jet fuel mix and which is the metering oil pump hose? right now I have 4 hoses and 3 fittings. pictures would be helpful.
Old Aug 12, 2007 | 02:39 PM
bmxer's Avatar
i hooked up the jet air fuel mix hose to the charge pipe, and the oil filler to the intake, now there are 2 more hoses, and only 1 connection, i hooked the hose that is under the jet air fuel mix hose to the intake assuming that is the right one. now in the pic there is a hose that i have no idea where it goes, anyone know? its the one left of the charge pipe, and it goes on the bottom of the intake manifold near the oil filter. it is a 06, and i looked at the 05's and they dont have it.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
