Flywheel
Old Aug 10, 2007 | 08:53 PM
Sovesky's Avatar
Sovesky
Flywheel
Will the lightweight zoom flywheel from my 1.3l rx-7 fit on my rx-8?
Old Aug 10, 2007 | 08:55 PM
Brettus's Avatar
Boosted Kiwi
probably will (not 100% sure) but you will definately need the RX8 counterbalance
Old Aug 11, 2007 | 12:40 AM
Do a search. Only certain year models will work from what I read.
Old Aug 11, 2007 | 12:46 AM
chickenwafer's Avatar
Nope
It should since it's a 240mm fly. Add a counterweight and you're good.
Old Aug 11, 2007 | 02:23 PM
Sovesky's Avatar
Sovesky
I was searching the internet for help also and the sites i found it on say to use the original mazda hardware. So do i need to purchase a new counterweight for it? and if so do you have any sites where it would be best to buy from?
Old Aug 11, 2007 | 03:03 PM
staticlag's Avatar
The Professor
The counterweight is the factory one used in the rx7 automatic.
You can usually find it on ebay for a bit cheaper, maybe $120, if you want to deal with ebay.
But I bought mine from
http://www.srmotorsports.com/RX8_Clutch_Flywheels.html
and I havent had a problem at all, fit perfectly.
Old Aug 13, 2007 | 04:27 PM
shaunv74's Avatar
Power!!
If you're not sure you can call racingbeat and they can tell you. I believe their flywheel for the RX8 is the same as the one they sell for the 1993-1995 FD RX7. They're always open to answer questions for rotary enthusiasts.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
xAgyex
Sep 28, 2015 08:54 AM
p8ntman442
Sep 23, 2015 09:18 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
