E-Shaft nut - how do you get it off !!!!!
Boosted Kiwi
help - Getting a bit frustrated trying to get the E-shaft nut off . Anyone got any tips .
Also : How do you lock the shft to stop it turning ?
the shop who did my FW install had to use Impact, cuz when your car is on a lift its almost impossible to take it off with bare hands. Even with a 400 lbs impact power it took him about 30 seconds of *papapapapapaPAPAPAPAPAPAPAPAPA* to get it loose. >_<
Impact will make this job 10000000000000000000 times easier,
I had a helper keep the wheel from turning with a huge screwdriver lodged against the exhaust manifold and flywheel teeth while I reefed on a breaker bar with my foot. It took a bit of effort but I have used this technique a few times and it always works.
are we talking about the flywheel nut or the nut on the front of the e-shaft that the pulley attaches to?
Yeah, to do the job easily you need a gun with 650+ ft-lbs of torque, should come off instantly. Anything less will take some time, even with the breaker bar and help sometimes it will approach impossible depending on how long your breaker bar is
Boosted Kiwi
Sorry - was talking about the front bolt - not FW bolt .
Do you have to take the starter motor off and lock the FW with a screwdriver ?
Or is there some other way to lock the engine ?
Need to replace front seal . I hope this is my mystery oil leak (that only appears on track days) .
Your thinking was reverse on the 1st gear issue, but I am glad you understand what I was saying. Yes, 280 lbs. is a lot and you'll need a breaker bar. Imagine the time I had getting mine off by myself while my engine was on the stand getting torn down. I succeeded, though.
Boosted Kiwi
hope to go to track tomorrow - will know after that if it is fixed or not . The old seal was a couple of mm larger inside diameter than the new one . fingers crossed .
send me an email with the outcome...
btw,, have big big fun.
jealous.
all is quiet on the home front.
you're suppose to use a special toothed piece tool that bolts to the back of the engine and engages the flywheel starter teeth to keep it from turning, $23 from Mazdatrix
using your trans is just asking for expensive problems down the road
I figured if I was able to use a breaker bar while my engine was on the stand there HAS to be an easier way while the engine is still in the car. Other than the use of an impact gun, I don't think the tranny will have a problem dealing with a person exerting 280 lbs. of torque on the bolt. Your idea is ultimately the safest one, though.
Boosted Kiwi
