Super charged 8 problem
Old Aug 10, 2007 | 05:34 AM
theboy's Avatar
RX8 newbie!
got a member here have problem with 8 jerking when change gear from 1 to 2nd. when u do a sudden gear change it jerks. whats wrong with it?
its a 4at, rpm is around 5k rpm.
i drove the car before and it seem like doesn't produce power of a sauper charge, it feel like a 4at rotary with pulley.
Old Aug 10, 2007 | 06:12 AM
expo1's Avatar
He's as bad as Can
He is releasing the clutch too fast??? Could be a bunch of things and there is not enough info in your post to give a better answer.
MODS, AT/MT, RPM when he shifts, does it happen in other gears?
Old Aug 10, 2007 | 10:51 AM
theboy's Avatar
RX8 newbie!
expo thanks for responding for the question
Old Aug 10, 2007 | 11:11 AM
DeViLbOi's Avatar
The devil made me do it
Uhh....what jerks? The back end?
Old Aug 10, 2007 | 11:23 AM
theboy's Avatar
RX8 newbie!
engine jerk,
engine check light came on
Old Aug 11, 2007 | 12:46 AM
Location of the MAF?
Old Aug 11, 2007 | 02:14 AM
theboy's Avatar
RX8 newbie!
u mean MAF of the tuning kit used. or the OEM MAF location?
here is some photo i took. i suspect the problem is with the stock intake. the stock intake wasn't able to produce efficient air. because when it jerk, its only less than 2 seconds. and u can hear the loud vacuum sound.
also i think there should be a boost controller for this super charge unit.
as u can see the super charger should be from blitz but funny that the top manifold is not by blitz. hmmm..... shouldn't it be a set?
Attached Thumbnails Super charged 8 problem-dsc01162.jpg   Super charged 8 problem-dsc01163.jpg   Super charged 8 problem-dsc01164.jpg   Super charged 8 problem-dsc01166.jpg   Super charged 8 problem-dsc01167.jpg
Old Aug 11, 2007 | 06:29 AM
theboy's Avatar
RX8 newbie!
here is somemore. i had match the super charge kit with the one published by blitz. doesn't seem to match 100%
Attached Thumbnails Super charged 8 problem-dsc01168.jpg   Super charged 8 problem-dsc01170.jpg
Old Aug 11, 2007 | 01:15 PM
effie's Avatar
Nightmares be gone...!!!
Benny, i don't think that a SC needs a boost contrller lar bro since SC boost is dictated by the SC kit belt pully size..... To change boost u need to change pulleys.....
Old Aug 11, 2007 | 01:19 PM
effie, you stole Tiggerlee's avatar!!!!!
Old Aug 11, 2007 | 09:15 PM
theboy's Avatar
RX8 newbie!
in an artical in Option Fans magazine interview with blitz, boost controller is a must, according to the blitz technition, due to the reason rotary is a hi-rev engine, piston engine, on hi-rpm when u de-accelerate then suddenly accelerate again, its easy to over boost, if the boost is set at 0.4kg/cm2 it will cause 0.1-0.2 extra boost occurs. the only way to solve this is using boost controller.
i hope i translate this from chinese with a readable english. lol
Old Aug 12, 2007 | 11:12 AM
sgrenesis's Avatar
THE GREAT WHITE
maybe you can check with cuscorex cause he has the blitz SC and maybe can give you more insight
Old Aug 12, 2007 | 01:13 PM
myriadshalaks's Avatar
rot8ing
i don't think the ecu management is set for US spec. If you don't have jdm, the blitz kit needs a remap. maybe that is screwed up.
Old Aug 12, 2007 | 01:32 PM
effie's Avatar
We're talking bout JDM Rx8's here..... FarEast = JDM RHD CARS..........
Old Aug 12, 2007 | 07:29 PM
theboy's Avatar
RX8 newbie!
Its a JDM version 4AT rx8.
the mechanic where the car is placed have the scan tools but he is only available on wednesday. he went oversea.
Old Aug 12, 2007 | 10:22 PM
effie's Avatar
moral of the story....... don't buy BLITZ SC Kit....... Keep ur 8 NA.... saves u from a hell of a lot of headaches !!!!!
Old Aug 13, 2007 | 01:05 AM
ProCharger GT's Avatar
a/s/l/n00dz?
I've never heard of a supercharger needing a "boost controller" - those are for turbo's only, because you can adjust the wastegate allowing how much air gets vented back into the atmosphere. Superchargers have bypass valves, which is probably what your referring to. Getting back to your problem at hand, who tuned the car? A/F ratio? Check the spark plugs?
Old Aug 13, 2007 | 04:17 AM
theboy's Avatar
RX8 newbie!
correct me if i am wrong, i remember not seeing a wastegate on this supercharger kit. and isn't wastegate something used in turbo
like i said, the boost controller is introduced by blitz rather than other mechanics. i guess by saying for rotary car u need boost controller for not over boosting in the article means u need them.
Old Aug 13, 2007 | 04:20 AM
Kane's Avatar
Senior Member
I am pretty sure ProCharger meant wastegate for the turbo. He is saying a Boost Controller is only needed to adjust the wastegate on a turbo, you don't need a Boost Controller on a SC, it uses pullys and a bypass valve.
Old Aug 14, 2007 | 08:41 AM
tubingchamp's Avatar
What mawd bug?
"got a member here have problem with 8 jerking when change gear from 1 to 2nd. when u do a sudden gear change it jerks. whats wrong with it?"
the same thing is happening with my 07 rx-8 with an MT, stock mazdaspeed cold air intake... but it is not supercharged..
Old Aug 14, 2007 | 09:49 PM
lennon's Avatar
I bought most of the Option Fans Mag from volume 50 onward, but didn't manage to get hold of that supercharge issue, i think it's volume 77 rite?? I think your friend needs tuning, Blitz Japan had warn that higher Ron fuel is required in order to counter detonation, plus hot wheather in Malaysia make it worst. why don't you ask your fren to use colder plugs NGK 5255 suggested by most forummer?
Old Aug 14, 2007 | 09:52 PM
lennon's Avatar
Blitz supercharged kit indeed comes with boost controller....
Old Aug 14, 2007 | 09:56 PM
MazdaManiac's Avatar
Feel like explaining how it works?
Old Aug 15, 2007 | 05:33 AM
theboy's Avatar
RX8 newbie!
no lennon, its volume 71.
