View Full Version : Wiring of front 02 sensor.... Help
erx8s
08-08-2007, 06:48 PM
I Searched but could not find a diagram showing the correct wiring of the front 02 sensor to get the correct readings from the catalyctic converter .
Having burnt out the stockcat , i replaced it with a Aftermarket Metalcat stainless steel one , i was told that it was indestructable well after only 9000km it burnt out .
I have found a complete second hand stock RX8 exhaust and decided to put it back on , at least the original stock cat lasted for 57,000km , but i need to know how to correctly wire up the front 02 sensor as some of the wiring has melted and came off .
Any help greatly appreciated .
Ben
http://img504.imageshack.us/img504/7190/metalcatgb0.jpg
TeamRX8
08-08-2007, 07:09 PM
just your friendly neighborhhood Team talking his usual pointless shizit :lol2:
erx8s
08-08-2007, 07:24 PM
Thanks , is this the right diagram ? because i believe MM pointed out that the RX8 Manual was initially incorrect with the wiring diagram of the 02 sensor :shocking: :boink:
Ben
SureShot
08-09-2007, 11:48 AM
I thought the stock cat had a government mandated warranty?
I'd have a straight pipe fabricated to bolt in the cat position and swap in a cat for a few days just to pass emissions testing.
Of course it would be loud.. :)
erx8s
08-11-2007, 12:33 AM
Wired up rear O2 Sensor everything seemed fine i cleared the ECU after 3 km the car goes into limp mode engine light goes on :banghead:
Once again i let engine cool down reset ECU Start her up as soon as cat gets to a certain temperature she goes into limp mode .
Any one know what to do , have i wired up the sensor wrongly ?
Ben
erx8s
08-15-2007, 02:33 AM
Bump
StealthTL
08-15-2007, 02:50 AM
You are trying to rewire the FRONT O2 sensor? The four-wire one?
Like Teams .pdf shows, the blue/orange and white/red wires go to the heater, you may have got the other two reversed, the colors are very similar (and I'm color blind...)
S
erx8s
08-15-2007, 06:56 PM
I am after the rear 02 sensor wiring , its shown on the diagram but is it correct ?
Ben
erx8s
08-22-2007, 04:10 AM
Bump
StealthTL
08-22-2007, 05:53 AM
Front, back, I don't see your problem - they are both on Team's .pdf?
That is a page from the manual, and it's correct....
S
JIN13
03-01-2008, 06:54 AM
I'm also looking for the rear O2 sensor wire colors any help????pics diagrams ???
GAMBEAN
03-02-2008, 09:22 AM
try 10 posts up for the answer.
nelsonrx8
03-02-2008, 09:36 AM
i wish i knew what i was looking at
HiTMaNN
03-02-2008, 11:01 AM
Fail...
StealthTL
03-02-2008, 11:25 AM
OK, Team did the hard work in post #2, so I will explain.....
The square marked Front Sensor has 4 wires -
heater power, red/white
heater switched ground, light blue/orange
sensor in, violet
sensor out, pink
The square marked Rear Sensor has 4 wires -
heater ground, red
sensor in, yellow
sensor out, black/red
The black/red wire may be useful for an air/fuel meter. Don't fuck with any of the others.
S
JIN13
03-02-2008, 04:24 PM
Thanks man this is what I was looking for........
sensor in, violet
sensor out, pink
heater ground, red
sensor in, yellow
S
Phish806
03-05-2008, 12:05 PM
Isn't the sensor before the cat going to be the most accurate reading, which would be the pink wire for the a/f gauge. correct?
SANTI
12-29-2010, 03:50 PM
is the sensor in the signal wire and the out the ground?
SANTI
12-29-2010, 03:51 PM
