Question about the a/c 's effect.
Old Aug 6, 2007 | 08:58 PM
NoOdLe BoY's Avatar
i know when the a/c is on it makes the car a little slower if u know what i mean, but when the a/c is off and i switch it so that air comes in from outside instead of cycling the air from inside the cabin, air blows out as if it were on. would this have the same effect as if i had the a/c on?? or is it just simply air coming from outside??? lol dont burn me!!!! im a newb!!!
Old Aug 6, 2007 | 09:09 PM
Silver_Surfer's Avatar
I4NI
As long as the AC is switched off you can use either outside or recir modes with no extra power loss.
Old Aug 6, 2007 | 11:34 PM
c41250n's Avatar
air from outside
Old Aug 7, 2007 | 06:56 AM
SureShot's Avatar
Basic aerodynamics.
When the car is moving, air flowing over the hood has to change direction at the cowl to go up the windshield.
This creates a high pressure area that car makers use as the cabin air inlet.
So you get some positive pressure air in the cabin with the fan off.
They also usually include an outlet vent in some low pressure area to help it along.
Here’s another point.
Airflow coming off the windshield at the A-pillar forms a low pressure area at the front edge of the side glass.
Up until the 70’s cars used to have a vent window there to exhaust cabin air (& cigarette smoke).
Old Aug 7, 2007 | 12:42 PM
NgoRX8's Avatar
^good info
yea, with air from outside your not killing your mileage as bad. but it wont be as cold as AC.
Old Aug 7, 2007 | 12:55 PM
StealthTL's Avatar
Metatron
Not so simple, Grasshopper.....
The a/c will try to de-humidify the incoming air whenever the control is set to send air to the windshield or feet.
The compressor will run and you are not saving any power (and the a/c light WILL NOT COME ON.)
....it is all in your manual.
The only setting that doesn't run the a/c is the "vent arrow".
Don't worry about losing peak power by having the a/c on, the computer switches it off at 75% throttle opening.
S
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
Wurromurro
Sep 20, 2015 05:02 PM
djp6783
Sep 19, 2015 12:12 PM
yankeepicker
Sep 11, 2015 05:42 PM
