grinding in fifth gear masda said is normal
Old Aug 6, 2007 | 04:47 PM
LPCOKIE's Avatar
i am getting grinding in fifth gear at high rpms like from 7 to 8 thousand took in to the local dealer and they said they talked with masda on the phone and were told this was normal at high rpms not under normal driving the dealer tech said he drove it under normal conditions and coudnt replicate the problem any way to get around this going from fourth to fifth or third to fifth under high rpms would also get grindings
Old Aug 6, 2007 | 06:00 PM
So are they saying high rpm driving is *not* normal ?
I think this car(Engine) was designed with High RPM operation in mind.
this sounds like some pure dealerships BS to me.
I do tons of high RPM shifts and none of my gears grind.
Old Aug 6, 2007 | 06:03 PM
mac11's Avatar
Rotary , eh?
have you ever changed your trans fluid(gear oil)? how many miles?
Old Aug 6, 2007 | 06:31 PM
shaunv74's Avatar
Power!!
1.8 quarts of Redline MT-90 will help. I would try changing your Trans fluid if it is the original.
Old Aug 6, 2007 | 07:05 PM
It will be hard to replicate since that's around 120 mph ...
Old Aug 6, 2007 | 07:21 PM
LPCOKIE's Avatar
i changed the oil 200miles ago
i changed to RP about 200 miles ago but it was grinding well before that
TeamRX8 that is their defense but if i am going up a on ramp in second or third and level out and go into fifth it grinds or if i am in fourth and about 6000 rpm then it grinds but you feel it not hear it
Old Aug 6, 2007 | 07:25 PM
mac11's Avatar
Rotary , eh?
Mine grinds if i want to skip 2 gears at once. No idea why. It doesn't grind going gear to gear or skipping 1 unless you are being a real ******* to it.
Old Aug 6, 2007 | 07:29 PM
LPCOKIE's Avatar
i admit i missed shift the first time in noticed the grinding i was trying for third and hit fifth i also noticed my spelling is bad masda is now mazda
Old Aug 6, 2007 | 08:53 PM
staticlag's Avatar
The Professor
I just took mine into the dealer for this, fifth gear grinding.
Mine happens when I rev at 6K+ and shift from first or second to fifth. A nice grind happens even when my clutch is at the floor.
The short story is my dealership is amazing and im getting the fifth and sixth gear syncros replaced under warranty.
Old Aug 6, 2007 | 09:51 PM
NgoRX8's Avatar
i'm with team. since the dealer can't get it to happen, it's not guna be replaced. especially if it only happens at speeds over 100. unless you want to take a tech for a drive and show him...
Old Aug 17, 2007 | 07:35 PM
BLACKOUT's Avatar
To the BATMOBILE!!!!!!
any new info please post b/c I have had this problem since i got the car with 9k miles on it and I am at 32k right now. exactly the same problem however It HAS GONE DOWN TO ALMOST NOTHING since i changed my tranny fluid to royal purple.
I don't like it never the less and would like more info on this to take as ammo to my dealer
Old Aug 17, 2007 | 09:29 PM
jones75254's Avatar
LOL, I took my 8 in due to grinding while shifting into 3rd and 4th gear at high RPMS, a service guy at Towne North Mazda here in Dallas told me they couldnt replicate the problem, i asked if they went above 5k rpm and he said NO because they were afraid of getting a citation from cops and that its not normal driving. i was like, are u freakin joking! Ur a bunch of idiots! I then took to Hancock Mazda and told them of problem, 10 days later i had my car back with both 3rd and 4th gears replaced (i have 04 6spd). I had them install Exedy stage II clutch while the tranny was out. DO NOT SETTLE UNTIL THE PROBLEM IS ADDRESSED, it all depends on the dealership. Its sad really, but thats the reality.
Old Aug 17, 2007 | 10:20 PM
costello's Avatar
Hmmm, I had this happen in my previous car too, (Honda Prelude) . What I started doing was to try to match the revs while the car is in neutral before I put it into fifth if I'm revving hard from second gear. Say you're at 9000 RPMs in 2nd gear so you're already going over 60mph (faster than most speed limits if you're not on the highway) and you've had enough fun so you want to put it into 5th or 6th gear. Here's what I do: push in the clutch and pull it out of 2nd into neutral, release clutch while car is in neutral, wait until revs drop to about 3k, push in clutch again and go into 5th. This way the input and output shafts are matched and the synchros don't have to work so hard.
Old Aug 18, 2007 | 10:26 AM
jones75254's Avatar
There should be NO grinding. PERIOD. If you are convinced it is mechanical and not from your driving style, then something is wore out and it needs replaced. I thought at first it was my driving but the problem got worse and worse and it would happen every time i got on it in those gears. Get to a reputable dealership.
Old Aug 18, 2007 | 01:35 PM
Charles R. Hill's Avatar
Owner of BHR
How soon we all forget about the crummy clutch pedal bracket and failing spot welds.
theblinkof
Oct 4, 2023 05:24 PM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
