Please help
Old Aug 5, 2007 | 01:45 PM
knightrider72's Avatar
knightrider
Please help
I have a 2004 rx8 mt.About a week ago i install an air filter kit APEXI.Now i have this kick at about 4000rpm.Before i was all normal.The only modification i done is the air filter kit.How i can fix this please help
Old Aug 5, 2007 | 02:02 PM
StealthTL's Avatar
Metatron
Ok, how about take the filter back off....
S
Old Aug 5, 2007 | 02:09 PM
knightrider
anything else this is not a soltion
Old Aug 5, 2007 | 02:17 PM
8 Maniac's Avatar
Senior Member
it sounds like it could be a solution... maybe not the solution you're looking for...
Old Aug 5, 2007 | 03:27 PM
chickenwafer's Avatar
Nope
I didn't even know Apexi made an intake kit for the 8?
Well try putting it back to stock, if it works, then you know your intake is junk. If not, then you f-ed something else up
Old Aug 5, 2007 | 03:46 PM
StealthTL's Avatar
Metatron
Make sure the little vacuum pipe (right below the throttle body) is capped off properly.
People who take off the stock box and all it's tubing often miss that cap.
S
