fan switch modification
Old Aug 5, 2007 | 01:22 PM
RXSeven1's Avatar
dorito spinner
on my rx-7 all i had to do was run 1 wire from the relay to a switch connected to ground in the cabin. Will this also work in the 8? if so where are the relays???
Old Aug 5, 2007 | 01:27 PM
StealthTL's Avatar
Metatron
Cool
Not so simple....
There are two fans, A and B, one is larger than the other.
There are three relays that control them, 1, 2 & 3.
....but there are only two control wires from the ECU.
Wire "r/g" when grounded, runs fans A & B in series, (relay 1) slow speed.
Wire "w/l" when grounded, runs fan A alone, (relays 2&3) full speed.
Both wires grounded runs, predictably, A & B in parallel, (relays 1,2&3) full speed.
The relays are with all the other relays in the fuse box.
S
Old Aug 5, 2007 | 03:29 PM
chickenwafer's Avatar
Nope
The same guy who just answered also has a DIY posted in the DIY Section.
You will need a zynther diaode as well
Old Aug 5, 2007 | 04:28 PM
RXSeven1's Avatar
dorito spinner
Originally Posted by StealthTL
Not so simple....
S
thanks, i read your other post but was a bit confused, the fd was easier, 2 relays, ground 1 for slow, ground both for fast.
Old Aug 9, 2007 | 08:48 AM
RX8Maine's Avatar
If you can go 2 weeks without driving your car, the Racing Beat reflash would be an option. It keeps the car cooler with earlier fan activation, and gives a few extra HP up top for about $300.
Old Aug 9, 2007 | 10:40 AM
SureShot's Avatar
I'm surprised that they don't always switch off when you're going over 30 MPH.
- (Or do thay?)
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jst4fun
Mar 5, 2021 07:16 PM
Digitz0070
Oct 7, 2015 12:43 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
