P-Rock
10-07-2003, 07:12 PM
I have looked every where and havn't found any info on gears. I was told that it may have a ford ranger rear end. If any one knows what kind of gears or what rear end the rx-8 matchs with it would be a big help.:D
View Full Version : Gears P-Rock 10-07-2003, 07:12 PM I have looked every where and havn't found any info on gears. I was told that it may have a ford ranger rear end. If any one knows what kind of gears or what rear end the rx-8 matchs with it would be a big help.:D Gord96BRG 10-07-2003, 08:03 PM Originally posted by P-Rock I have looked every where and havn't found any info on gears. I was told that it may have a ford ranger rear end. If any one knows what kind of gears or what rear end the rx-8 matchs with it would be a big help.:D It's pretty widely published and discussed that the RX-8 uses a torque sensing limited slip differential manufactured by Tochigi-Fuji corporation of Japan (same as Torsen LSD). I'm pretty sure those aren't used in a Ford Ranger! Diff ratio is 4.44:1 (also unlikely to be found in a Ranger). Regards, Gordon P-Rock 10-08-2003, 06:48 PM Thanks for the info, do you think there will gear replacements in the future as aposed to replaceing the housing? |
