power loss question
Old Aug 4, 2007 | 01:13 PM
rg200amp's Avatar
gr8ness
next time the CEL comes on, dont clear it, you sould have got it scaned to see what code it was thowing. id say if the cel comes on take it to auto zone, they scan for free. or just wait to go to mazda.
Old Aug 4, 2007 | 06:01 PM
RxJaye's Avatar
MIL (cel for you guys) flashing means a mis-fire strong enough to damage the Catalyst. You probably have a coil or wire fault. have that checked first. while you are there u should have the compression chewcked as well. My power loss was loss of compression which in turn means a new engine.
Old Aug 4, 2007 | 07:50 PM
shaunv74's Avatar
Power!!
Could be clogged cat or coils gone bad. don't clear out your CELs. Leave them so Mazda can download them and see what the computer thinks is wrong.
Old Aug 5, 2007 | 11:42 AM
mazdatech177's Avatar
did you put the plug wires back on the plugs so they fit tight... they like to fall off after replacing the plugs. check and make sure you didnt crack a plug also
Old Aug 5, 2007 | 04:07 PM
silvercloud's Avatar
As Shauny said , the catalytic converter could be bad or the coils.
When my cat went out I got a flashing CEL
When my coils went the CEL went from flashing to solid and then lost power so much it was not drivable.
They pulled the codes at the dealership and knew what to fix right away.
They should have both of these items in stock as this is a known issue with the 8
good luck
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
uZu
Dec 30, 2015 12:35 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
