Corners...
Old Aug 4, 2007 | 09:27 AM
RX8USMC's Avatar
Corners...
are 194 bulbs the only lights that will fit/work on the corners?
Old Aug 4, 2007 | 09:32 AM
ac3mastuh's Avatar
Got Ings?
yep, 194 are the corner bulbs.....I supposed you could try to rebase them for something else but its more of a pain than its really worth
Old Aug 4, 2007 | 05:15 PM
Aipex8's Avatar
X e p i A
That's not correct actually, 921 bulbs (which are a larger bulb with the same base as a 194) will also work in the corners, although they will not fit in the parking lights. The opening for the bulb in the corners is about 16mm, but the parking light opening is a bit smaller, maybe 14mm. Most LED 921's are about 15mm in diameter. The following bulb from V-LEDs.com should fit as it is 15mm... I'll probably order in the next week or two (also available in amber).
Old Aug 6, 2007 | 08:56 AM
ac3mastuh's Avatar
Got Ings?
^thanks for informing me!.....i put in some LED 194's and they barely fit so I didn't think we could fit anything larger
tarteman
Good Guy/Bad Guy
May 23, 2011 05:11 PM
HWK11
May 23, 2010 11:48 AM
Thorrsson
Canada Forum
Dec 12, 2009 03:00 PM
nrgtrx8
Mar 27, 2009 09:11 AM
Crazy Rx-8 Driver
103
Mar 29, 2007 08:46 PM
