These coils are CRAZY
Old Aug 4, 2007 | 02:15 AM
kudlockm's Avatar
I've never seen anything like these RX-8 coils. I went out to test them with my trusty multimeter and they raised more questions than answers. On a normal car, if you ohm out the path between the high voltage output of the coil and the engine block you would usually get something...not on these coils. I got nothing. I even went so far as to pull all 4 of the coils to test if there was a ground path, I came up with nothing, not from the mounting point, not through any of the three terminal connections, nothing. I've got more than my share of electrical knowledge but I'm completely stumped. If the voltage coming out of the coill jumps the spark gap into the outer shell, then into the engine block, where does it go from there with no apparent return path. Is it akin to some sort of tesla coil? Please someone help me out, It's bugging the hell out of me!
Old Aug 4, 2007 | 03:47 AM
you have much to learn, grasshopper ...
http://www.finishlineperformance.com...16-07-1793.pdf
Old Aug 4, 2007 | 08:42 AM
kudlockm's Avatar
That's a good explanation on how to troubleshoot, but I'm looking for more of a theory of opperation. The voltage/current usually takes a path like...coil->sparkplug wire->sparkplug center terminal->spark plug outer shell->block->coil. In every other car I've had, the path from the block back to the coil is either through a ground strap, a grounded mounting point, or a waste spark system. These coils have no apparent return path. how can electrons move without a return path?
Old Aug 4, 2007 | 12:28 PM
they're direct ignitor coils, and the link I gave you shows how to properly test them with a multimeter, now learn how to search n00b ...
like I said, you have much to learn
Old Aug 4, 2007 | 02:05 PM
kudlockm's Avatar
Learn how to read, douche.
I'm not worried about troubleshooting them!
I'm not worried about testing them!
I want to know where the high tesnion return path is back to the coil.
Old Aug 5, 2007 | 02:56 AM
chickenwafer's Avatar
Nope
Old Aug 5, 2007 | 11:31 AM
mazdatech177's Avatar
notice in the bulletin that was shown that it states that these coils have built-in power switches. terminal b is your pcm triggerfor the primary circuit and terminal c is your path to body ground. from what i read about the power switch, you wont have a return path until the secondary circuit fires.
Old Aug 5, 2007 | 11:45 PM
Nubo's Avatar
Lubricious
Yes, very much like a Tesla coil.
Old Aug 6, 2007 | 07:14 PM
try reading yourself, especially the part about "direct igniter coil" (also see mazdatech's post above had you chosen to read the link), then try doing some research since you obviously have no experience with what that is ...
there must be at least a dozen discussions on RX-8 coils and their function on this forum alone
and if you really want to shock me, showing some intelligence will work better than calling me a douche, lol ...
Old Aug 7, 2007 | 12:05 AM
which came first; the chicken or the egg?
Old Aug 7, 2007 | 12:14 AM
The glint in the eye of the rooster
Old Aug 7, 2007 | 01:10 AM
Nubo's Avatar
Lubricious
http://www.youtube.com/watch?v=3ff_AXVlo9U
Old Aug 7, 2007 | 02:14 AM
MazdaManiac's Avatar
You guys are having too much fun.
They aren't just coils. If you want to find the "path to ground", you aren't going to do it with a multimeter. You need to bias the ignitor and then measure the current.
Old Aug 7, 2007 | 02:41 AM
this guy got a pass?????
https://www.rx8club.com/series-i-tech-garage-22/ring-pinion-123750/
huh.
Old Aug 7, 2007 | 11:20 AM
https://www.rx8club.com/showthread.php?t=123750
huh.
slackers
Old Aug 7, 2007 | 02:05 PM
gc1bflyr's Avatar
This should help
http://en.wikipedia.org/wiki/Ignitio...ronic_ignition
Old Aug 7, 2007 | 08:00 PM
Easy_E1's Avatar
If you want to find the path to ground, unplug the plug wire, stick a screw driver in the end and hold on to the metal end, and stand barefoot in some water.
Then turn the key to start.
I'll bet it will be your feet.
Old Aug 7, 2007 | 08:01 PM
WoodsOfGreenRx8's Avatar
Try working with a Lincoln LS.. I've had 6 coils go bad this year alone. I hate Fords Coils..
Old Aug 7, 2007 | 10:43 PM
Ask Mazdamaniac. You'll find his mannerisms much more to your liking.
Now that's funny!
Old Aug 7, 2007 | 10:50 PM
I thought my response was quite pleasant. So, what shall be your contribution to this, Razz?
Old Aug 8, 2007 | 10:59 AM
Originally Posted by Razz1
Now that's funny!
Old Aug 8, 2007 | 03:06 PM
he got a pass too in post #2 above despite posting like a 'tard in #1, but I have no empathy for mouthy n00bs ...
Old Aug 8, 2007 | 08:43 PM
your are getting soft...
Old Aug 9, 2007 | 09:43 AM
PaSs1oVeR's Avatar
Likes to eat rice.
the chicken did ....... aliens brought em here
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Sheldon24
Sep 21, 2015 04:53 PM
Vedivan1
Sep 18, 2015 12:39 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
