19x10.5 question
Old Aug 3, 2007 | 09:09 PM
sauceyI986's Avatar
19x10.5 question
I know a couple of people on the forum that are running 10.5's on the back I my car I was wanting to go with 19's and wondering what is all involved in doing that setup.
Old Aug 4, 2007 | 09:34 AM
ac3mastuh's Avatar
Got Ings?
The key is to choose the correct offset as well as tire size
don't quote me on this but you'll probably need something like a +45ish offset as well as stretch a 275 tire to make it work.
Old Aug 4, 2007 | 11:49 AM
I have 18 x 10.5 +43 on all four corners lowered with no fender mods
+45 is about as far inboard as you can go with 10.5" in the rear to clear the fender lip. Anything lower will require flattening or removing the rear fender's lip flange. Anything past +35 will require rolling/flairing the fender to have proper clearance.
Old Aug 4, 2007 | 12:37 PM
Macius8's Avatar
^^what tires are you running?
Old Aug 4, 2007 | 01:30 PM
sauceyI986's Avatar
TeamRX8 how low is your car
Old Aug 6, 2007 | 08:59 AM
ac3mastuh's Avatar
Got Ings?
I believe that TeamRX8 is running a 265/35/18 Advan Neova which is actually a bit wider than a standard 275/35/18
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
