constant power wire?
Old Aug 1, 2007 | 03:56 PM
kevinD1226's Avatar
so i installed my aftermarket dvd player in the rx8 and the power wire i accidentally tapped into the ciggaret lighter outlet thinking there was constant power there and i found out there isnt.. can anyone help me in lettin me know where i can find constant power so i can fix my headunit?
Old Aug 1, 2007 | 03:59 PM
StealthTL's Avatar
Metatron
The fuse by your feet marked "room" has constant power.
S
Old Aug 1, 2007 | 04:08 PM
kevinD1226's Avatar
thanks man ill have to cut into that waire and solder it up thanks i appreciate it
Old Aug 2, 2007 | 09:57 AM
kimota's Avatar
You dont have to cut any wire and solder just pickup a add a circuit fuse tap at Pepboys (the cost like $3 bucks). Remove the fuse place it in the fuse tap, plug in fuse tap, wire from fuse tap will give you your power source. : )
gwailo
May 14, 2024 06:57 AM
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
Cookingislife1226
Mar 20, 2016 09:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
stickmantijuana
Jul 19, 2015 10:33 AM
