Quick Valve - Fram Sure Drain Knockoff
Old Jul 30, 2007 | 11:22 PM
xr8ed's Avatar
http://www.harborfreightusa.com/usa/...o?itemid=94879
I found this thing on sale so I figured it wouldn't hurt to try. Does the RX8 take F106 with a M14 x 1.5 thread plug?
Thanks for your help.
Old Jul 31, 2007 | 11:41 AM
Jax_RX8's Avatar
Got Another Rotary
Use a Pela Oil extractor instead - then you don't have to crawl under the car at all.
I have this model and it works great with the 8 - I can get a solid 5 quarts out with it while most others can only get 4.5 quarts out on a change.
http://www.overtons.com/modperl/prod...w&i=27266&aID=
Old Aug 1, 2007 | 09:12 AM
SureShot's Avatar
I used the Fram drain on an 87 RX-7.
It worked but the flow was slow so it took a long time to drain the sump.
I'm not crazy about jacking, but it's good to periodically have a look under the car for other problems.
Old Aug 1, 2007 | 11:07 AM
Nubo's Avatar
Lubricious
Fumoto Valve here. 3 years; works like a champ.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Evan Gray
Nov 24, 2015 01:00 AM
RXBae
Sep 14, 2015 03:54 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
