will it blend? s2k trans in rx8?
Old Jul 30, 2007 | 06:36 PM
RoXanneBlack8's Avatar
stop flooding ur engines
just wondering if anyone here is a honda guy and can shoot down my hopes and dreams of the s2k trans in my rx8......
well is it possible?
Old Jul 30, 2007 | 07:02 PM
MazdaManiac's Avatar
I'm not sure why you would bother - abbid is correct.
I don't know what the gear ratios are on the S2000 version, but it can't be too far off the '8 since they have a similar power band.
Old Jul 30, 2007 | 07:20 PM
Vasichko's Avatar
Would this possibly be a stronger tranny?
Old Jul 30, 2007 | 07:23 PM
mysql101's Avatar
When someone tells you "they're the same exact box", that means one is stronger than the other.
Old Jul 30, 2007 | 07:25 PM
"This one is so much better than the other that its identical!"
Old Jul 30, 2007 | 07:30 PM
mysql101's Avatar
Exactly. Here's the proper way to use it in a sentence:
"Your quarter mile time sucks. I'm going to show you how it's really done by posting an identical time."
Identical means better. It comes from the root words, "I'm dating identical twins."
Old Jul 30, 2007 | 07:38 PM
Identical twins are often surprisingly different...
Old Jul 30, 2007 | 07:41 PM
mysql101's Avatar
ergo, they're identical.
Old Jul 30, 2007 | 08:03 PM
mac11's Avatar
Rotary , eh?
Same box =/= same mechanicals.
Old Jul 30, 2007 | 08:08 PM
oooo ok, i didnt kno they were the same....i drove an s2k a few weeks back and it just seemed, smoother.....
maybe it was all in my head....
Old Jul 30, 2007 | 08:11 PM
MY '8s transmission/clutch is smoother than both of my Miatas, which have the best shift feel of any vehicle ever made.
Its all in the adjustment and shifter.
Old Jul 30, 2007 | 08:40 PM
Vasichko's Avatar
Sorry long day at work, didnt catch that at all.
Old Jul 31, 2007 | 12:57 AM
8 Maniac's Avatar
Senior Member
are you talking about twins or transmissions?
Old Jul 31, 2007 | 01:11 AM
I presume the trans because it is definitely not true about the twins.
Old Jul 31, 2007 | 01:26 AM
it's the weak link in the car, ask any serious RX-8 race team
Old Jul 31, 2007 | 01:53 AM
chickenwafer's Avatar
Nope
Like others mentioned- it should fit and work, but is it worth it? Iwould od more research to see if the S2k trany is strong. There are some S2k's out there putting down some serious power figures- see if their tranny's go at 400-rwhp.
Old Aug 1, 2007 | 05:06 PM
rotarenvy's Avatar
if they are the same then the s2000 kits ppg have would be a direct fit.
http://www.ppgearbox.com.au/default.htm
they already have a syncro and a dog engagement for the s2000
Old Aug 1, 2007 | 06:06 PM
CodingParadox's Avatar
The s2k tranny is definitely much smoother and more precise than the RX-8 box. If it really is the "same box", which I really doubt, then I dunno what they did to gimp it out for the RX-8, but it's unfortunate that they did.
Old Aug 1, 2007 | 06:13 PM
r0tor's Avatar
i thought they had carbon synchros in the S2k tranny... or something like that anyway
Old Aug 1, 2007 | 06:16 PM
They switched to, I believe, CF synchros in ~2004, after the (brass? bronze?) original ones started all blowing up.
Old Aug 1, 2007 | 06:23 PM
124Spider's Avatar
2004 and later S2000s have carbon synchros (and ratios in at least some gears different from earlier versions). But that is only a tiny bit of how the two gearboxes feel different.
The RX-8 gearbox is fine for any normal use, and for most abnormal uses. Having driven our RX-8 and our S2000 a great deal, the real difference is how precise and smooth the S2000 gearbox is (and I don't have to hunt/fight to get it into reverse in the S2000). The S2000 gearbox is often called, in car mags, the best gearbox of any production car, and I would believe it. I can't believe that they are the same box, given how incredibly different they feel.
That said, I have no idea why anyone would want to go to the trouble and expense of putting an S2000 gearbox in an RX-8, unless (i) your present gearbox is shot, and (ii) it is a relatively simple procedure (which I doubt).
Old Aug 1, 2007 | 08:33 PM
By the same token, many of the mags have called the Miata gerabox the best ever made.
It is also the same Aisin A-1 Y6M transmission.
Much of the "feel" comes down to how accurate the clutch release and shift lever pivot are.
Old Aug 1, 2007 | 08:40 PM
Nope
I personally wouldn't bother with it. Slide in an FD 5-speed which can handle massive abuse and call it a day
Old Aug 2, 2007 | 08:51 AM
savedsol's Avatar
Carbonormous
Sure it can but it's not geared right for an NA Renesis. I'd be interested to know if the S2K tranny is a straight bolt up. Mine's shot to shizzle.
Old Aug 2, 2007 | 09:14 AM
mac11's Avatar
Rotary , eh?
2004 honda ratios
1st Gear Ratio: 3.133:1
2nd Gear Ratio: 2.045:1
3rd Gear Ratio: 1.481:1
4th Gear Ratio: 1.161:1
5th Gear Ratio: 0.942:1
6th Gear Ratio: 0.763:1
2004 RX8 ratios
1st - 3.760
2nd - 2.269
3rd - 1.65
4th - 1.187
5th - 1.000
6th - 0.843
Parts out of the honda box fit our box?
