FS:K-Sport coilover package $550
Old Jul 26, 2007 | 01:16 PM
PhotoMunkey's Avatar
Hi everyone! I'm selling my K-Sport coil-over set, complete with two pairs of rear springs, one 6.5 kg/mm (street/track) and one 8.0 kg/mm (hardcore track/drifting). The front spring rate is 10 kg/mm. They are single-adjustable fully threaded shock bodies with adjustable locking perches and bottom-adjustable for height (front and rear). I still have the original shipping box and all hanger tags. $550 for a low-mile coil-over package (I've only done about 4000 on them).
Full "soft" is a little firmer than the stock shocks, but with much better rebound control. Full hard would be recommended for R-compound race tires and provides excellent grip and control. With an ultra-high performance street tire, the middle setting is great for a smooth track, and results in lap times which will make you the envy of all the other HPDE drivers. I've seen this done with my own car when driven by one of NASA's track instructors! The spring rates (562 lbs/in front and about 380 lbs/in rear) are set so that you don't NEED any more than the stock anti-roll bars. This is the proper method for setting up a track car (consult a suspension book or ask experts if you don't believe me).
So if they work well, why am I selling them? Just to go and try something different (I'm thinking Bilsteins on Eibach Pro-kit springs. I really don't need the super-low drop the K-Sports can provide, and with my job right now I'm not getting to any track days. <sigh> I thought originally that I'd get to the track a lot more this year. Sadly that isn't happening. Since I already have the Eibach springs, I just need a set of Bilstein shocks.
If interested, send me a private message or call my cell at 760-799-0368. I'll post photos of the package later today.
Eric
Old Jul 26, 2007 | 01:26 PM
Here are the photos:
Attached Thumbnails FS:K-Sport coilover package 0-front_assembly.jpg   FS:K-Sport coilover package 0-rear_assembly.jpg   FS:K-Sport coilover package 0-front_top.jpg
Old Jul 26, 2007 | 08:05 PM
dmak_el's Avatar
so what's the minimum drop on those?
and since spring rate are so high, how does it drive on street? jumpy at rough/bumpy road?
Old Jul 26, 2007 | 08:19 PM
I'd say the fronts will do 25.5" in the front pretty comfortably. 25.75" was pretty much it in the rear if you wanted any preload on the spring. It's possble to go MUCH lower (like ricer-boy low) if you take out the preload completely front and rear but you'd have to make some thin rubber donut washers to keep the springs from rattling like crazy on the perches. This attached photo shows how I had the car set up.
I'd say that freeways were a little bumpier than I prefer, but keep in mind that just one full turn up on these shocks gets VERY STIFF in a hurry. Tein Flex rates are 9 kg/mm front, 7 kg/mm rear so a 10/6.5 isn't very far off. JIC-Magic's track setup is a 10kg/mm front, 7 kg/mm rear too. Tein's rates are set up to use Tein's anti-roll bars. K-Sport's doing all the roll control with the springs. If you're coming from a typical lowering spring, the job this kit does to keep the car level is just amazing. I've tried it with the stock sways and with a set from Progress Technology. Roll control from the higher spring rates simply rules in the corners. If you're going to do a track day with R-compound tires, this is the setup to use as it really plants the outside tires in the pavement!
It never felt like it was going to come out from underneath me on bump roads as long as I kept the shocks set below .75 of a turn up from full soft (which in this case was already stiffer than stock). Much less "float" than the stock shocks too.
All in all, the K-Sport kit appears to be a great value... solid build, wide selection of spring rates (if you want to run a 9/6.5 setup, you can get new front springs from K-Sport directly over in Phoenix, AZ), quality bump stops provided, quality hardware and fasteners provided. I just want to try something different now. I hope this answers your questions.
Old Jul 26, 2007 | 08:41 PM
dmak_el's Avatar
um...i don't really understand what u mean by 25.5" in the front and 25.75" for the rear.
maybe i should ask like this, how much do they lower the car? compair to stock suspension. Like the range? maybe lower from 1"to 3" something like that?
Old Jul 26, 2007 | 10:25 PM
I think stock was something like 27.5" at the center of each wheel arch. My car hasn't been stock in so long that I can't remember exactly. I think this K-Sport kit will go from stock ride height to something like a 2.5-3" drop. For shows, you can take the preload completely out and go even lower for a "fully tucked" look.
Old Jul 26, 2007 | 10:27 PM
Photos of my K-Sport dropped RX-8:
Attached Thumbnails FS:K-Sport coilover package 0-project_rx8_1.jpg   FS:K-Sport coilover package 0-project_rx8_3.jpg   FS:K-Sport coilover package 0-project_rx8_2.jpg
Old Jul 26, 2007 | 10:34 PM
that's the ride height measurement from the ground to the top center of the fender arch lip as noted
Old Jul 26, 2007 | 10:36 PM
dmak_el's Avatar
very nice, well, i did some research, and find that it will most likely too stiff for what i need. I need something for daily driving, and this just wouldn't fit in for my needs. this set up is more for track use.
But it's very good price, and i find some good review on them too. good luck with the sale.
Old Jul 26, 2007 | 10:37 PM
Team, Do you happen to remember what the stock wheel arch height is?
Old Jul 26, 2007 | 10:50 PM
it's around 27.5" give or take 1/8"
Old Jul 26, 2007 | 10:55 PM
Just bear in mind that "stiffness" is a shock function, not a spring function. A heavy spring simply returns the wheel to its "at rest" position faster than a softer spring. A "stiff shock" will provide a jarring ride, but can better control the rebound motion of a heavy spring. An "adjustable shock" usually has a range from soft (street ride) to firm (track ride) which more heavily adjust REBOUND and not Compression (or if it does Compression, just a fraction of the amount that Rebound changes). The reason is, tires don't like "infinite spring rate". They break traction when they can't move upwards in response to a bump. Hence, suspension engineers don't design shocks with much control over Compression. They set Compression based on the weight of the car. They select spring rates based on the target "Ride Frequency".
In other works, set for full soft on the shocks, this set has a plush ride, even over bumps.
Old Jul 27, 2007 | 04:02 AM
PNTitBLK_07's Avatar
well i may be interested, i dunno, have to do little research first, also can you ship to hawaii???
Old Jul 27, 2007 | 10:07 AM
VASasha's Avatar
Where are you located PhotoMunkey?
Old Jul 27, 2007 | 02:28 PM
I'm in southern California... I thought it was appearing in my signature. Duh.
Old Jul 27, 2007 | 02:58 PM
VASasha's Avatar
It's not. Not to me at least.
Old Jul 29, 2007 | 01:53 PM
I can ship to Hawaii... Not's not a problem.
Old Jul 29, 2007 | 02:53 PM
>speedaddict<'s Avatar
United States Marine
Im Interested but i have to wait 3 weeks. if im lucky you will still have them.....
Old Jul 30, 2007 | 08:24 PM
Well they don't appear to be going anywhere at the moment, so you might be in luck!
Old Jul 30, 2007 | 11:10 PM
GOOD CUZ I REALLY WANT THEM lol.
Old Jul 31, 2007 | 04:32 PM
Are you in Ontario, Canada? I'm just curious...
Old Jul 31, 2007 | 10:44 PM
nope ontario california... If You Wanna Ask Me More Questions Call Me At My Cell At 909 730 2162. 2 Weeks Left Then There Mine!!... Hopefully...
yurcivicsux
192
Sep 12, 2017 10:54 PM
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
