2 quick/easy questions... yeah I searched
Old Jul 21, 2007 | 01:27 PM
JeremyG's Avatar
Viva Las Vegas
I must be bad at searching, I can't find an answer to these questions...
1. Where is the antenna? Top of the rear window? I have a new Roady3 with the direct antenna hookup thingy and need to put the "transmitter" right on the antenna.
2. Is there a direct input somewhere on the factory head unit (04 with the Bose)? I'd much rather hook the XM directly to the head unit if possible. If there's a direct connect, where is it and is there directions on how to hook to it? Is it just an RCA connection?
Thanks in advance, I realize the answers are somewhre but I've spent like 30 minutes searching with no clear results.
Old Jul 21, 2007 | 03:30 PM
expo1's Avatar
He's as bad as Can
1, I am not sure if that connector at the top of the rear window is for the radio or rear defrost. You can disconnect it and see which thing doesn't work.
2, You can connect a FM Modulator to the head unit, this thread talks about it.
https://www.rx8club.com/series-i-interior-audio-electronics-24/invisible-bolt-when-removing-stereo-head-unit-103962/
Old Jul 21, 2007 | 03:36 PM
DeViLbOi's Avatar
The devil made me do it
2) Forget that FM Modulator crap...Direct Connect FTW!
http://www.autotoys.com/x/cust/produ...roductid=10025
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Evan Gray
Sep 26, 2015 12:30 PM
p8ntman442
Sep 23, 2015 09:18 PM
