metalurgical question
Old Jul 21, 2007 | 02:42 AM
juikster's Avatar
Im 8 drifting on a budget
I aquired a set of 3" 304 S.S. exhaust tips that I want to weld onto my 3" 304 S.S. turbo xs catback tailpipes. once I cut off the existing tips and slip the new ones,what type of welding rod do I use if I only have an aceytlene-oxy rig available? will I have to have it done with a mig setup? just wondering. Thanks
Old Jul 21, 2007 | 03:05 AM
Kane's Avatar
Senior Member
Are you saying you have an oxy acetalyne torch? I have never heard of an oxy acetalyne welder. You can weld with the torch, but the quality of the welds are iffy and they don't tend to penetrate much.
Rule 1 - any time you weld dissimilar metals there will be corrosion.
TIG welding would be the cleanest and easiest way. You can get SS welding rods, but for small stuff they are hard to use.
Old Jul 21, 2007 | 08:52 AM
DarkBrew's Avatar
Extraordinary Engineering
You need to TIG weld stainless steel.
Oxy acetalyne will damage stainless.
Old Jul 21, 2007 | 10:38 AM
Wilson's Avatar
Peeping over the fence
+1
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
