I got oil coming out my a*ss
Old Jul 18, 2007 | 12:51 AM
BigOLundh's Avatar
#1 Legend
So after work today i notice some oil under my car, pull forward a bit and see a pool. There was a bout .25 to .5 of fresh quart of oil on the ground.
Since i am gone sunrise to sunset, i wont get a chance to look under the car till saturday to find the leak. Any suggestions on where to start?
BigOLundh's Avatar
#1 Legend
oh and... thanks in advance.
Old Jul 18, 2007 | 01:35 AM
MazdaManiac's Avatar
So many possibilities. Can you tell, more or less, where on the block the oil was coming from?
That's a lot of oil. Maybe your filter is loose or the seal on the pan failed.
Old Jul 18, 2007 | 01:45 AM
paulmasoner's Avatar
Asshole for hire
damn that sucks bro..... if you want a hand poking around this weekend give me a call. more than happy to help out in anyway i can. even if it just handing you beer, lol
Old Jul 18, 2007 | 02:36 AM
Flashwing's Avatar
3-wheeler
As MM suggested...a loose filter or drain plug would be two possible places. Beyond that, grab a flashlight.
Old Jul 18, 2007 | 03:06 AM
BigOLundh's Avatar
#1 Legend
word. i really wont be able to say more until i get under there. at least since the leak is so severe... it should be easy to spot. ill post back up when i get under there saturday.
paul.. ill call u sat morning
Old Jul 18, 2007 | 05:42 AM
Ro-T8's Avatar
give 'er some stick!
Have you had a local "quick lube" type place change your oil lately? Had this happen one time on a Honda I owned. Turns out they put 2 gaskets on the oil filter. When there's 2 of them, they get smashed out of the recess they are supposed to fit in, and don't seal. They claimed it must have come out of the box that way, but maybe the gasket of the old filter stuck to the block when the filter was removed.
Good news is that if you haven't had a low oil light come on, you probably didn't drive it too long with low oil and shouldn't have any damage. The RX8 low oil light actually does a good job. Fix the leak and you should be rockin'.
Old Jul 18, 2007 | 05:54 AM
Asshole for hire
^^ i guarantee you that is not the case
Old Jul 18, 2007 | 06:20 AM
BigOLundh's Avatar
#1 Legend
i change my own oil. thanks anyway for the suggestion... reminds me why i dont take my car to quick lube. LOL
Old Jul 18, 2007 | 11:43 AM
please, no threads on **** leakage ...
Old Jul 18, 2007 | 05:56 PM
alnielsen's Avatar
Put a fresh piece of cardboard under the car. This will help you locate where the leak is. When you park the car, you move around a little and that makes it impossible to localize where the leak is coming from.
Old Jul 18, 2007 | 06:16 PM
BigOLundh's Avatar
#1 Legend
im gonna clean down the existing oil today after work. I have about an hour of time between when i get home and when the sun sets. Then i'll put some cardboard down. I doubt it will leak a lot since the car hasnt been driven for a while. I have to make a run to the airport tomorrow night. After i get home ill put the cardboard back to see what i find the next time i get a chance to get under it.
Thanks for the suggestion. I remeber doing that in the past with previous cars... but forgot about it.
My friend who is flying in tomorrow night is one of the friends that helped when i installed the turbo kit.. i think ill have him look for the leak on friday while im at work. Nothing says Hawaiian Vacation like fixing the BigOOilLeak. LOL. Hopefully i can get this taken care of soon so we can cruise the island while he's here. Also if he wants to drive the car while im at work next week.. the oil fix is gonna be a must.
-hS
Old Jul 18, 2007 | 07:30 PM
Spin9k's Avatar
Momentum Keeps Me Going
I'll wager a blow o-ring on an oil cooler hose, probably at the engine. $5 anyone?
Old Jul 18, 2007 | 07:47 PM
mac11's Avatar
Rotary , eh?
not enough info to make that bet. I'll speculate its possibly a blown seal or bad fitting on the turbo.
Old Jul 18, 2007 | 08:22 PM
BigOLundh's Avatar
#1 Legend
i hope for the sake of my wallet... that both of you are wrong.
Im pretty sure its not the turbo since the resposne from the turbo has still been normal.
Old Jul 18, 2007 | 09:02 PM
mac11's Avatar
Rotary , eh?
How far did you drive it like that? And you drove it hard enough to get into boost?
Old Jul 18, 2007 | 11:53 PM
BigOLundh's Avatar
#1 Legend
i didnt drive it in boost after i noticed that leak. but that morning i was boosting on the way to work.
i keep a few quarts in the trunk, so i topped it off before going home. Plus i kept an eye on the oil pressure gauge (aftermarket, not the oem gauge)... the whole way home.
Old Jul 18, 2007 | 11:54 PM
BigOLundh's Avatar
#1 Legend
SO...
i was too beat after work to get under the car. I did look around in the engine bay and found no oil. None coming out the BOV (thank god that problem has been solved), none near the oil filter and none around the block of the engine. narrowing down the options
-hS
Old Jul 23, 2007 | 09:44 AM
Is there any left in the motor?
Old Jul 23, 2007 | 10:05 AM
Michael's Avatar
I just had to replace the Oil Separator on my Porsche for a similar reason - it was blowing oil into the intake and blowing huge plumes of white smoke out the tailpipe.
Different scenario and different car with you though.
Old Jul 24, 2007 | 03:36 PM
BigOLundh's Avatar
#1 Legend
the oil stopped leaking. real odd. i filled it up saturday, and keep checking it and theres no loss or leak under the car. Still havent got a chance to get under the car - been super busy. but ill make time to do it next weekend.
Old Jan 9, 2018 | 06:00 AM
BigOLundh's Avatar
#1 Legend
i never posted the end to this story.
they oil was coming from the oil pan to turbo return feed hose. The hose was damaged from road debris. Simple fix.
Old Jan 9, 2018 | 09:55 AM
That'll do it. Thanks for the update, I was checking back everyday to see what happened.
Old Jan 9, 2018 | 10:46 AM
NotAPreppie's Avatar
What am I doing here?
10.5 year autonecromancy.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
drebbrnator
Dec 27, 2018 07:02 PM
Dokuji
Nov 1, 2016 02:51 PM
talonhart2
Aug 26, 2015 04:14 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
