oil gets dark really fast
Old Jul 17, 2007 | 04:04 PM
imrtommy's Avatar
Need Rotary Engine!!!
My oil has been turning dark brown very after 2 days after the oil change. Before it usually lasts a week before turning brown. I use mobil1 super synthetic 5w20 which is a very bright gold color. I buy the big 5quart and usually use 3/4 a quart to drain out the rest of the black used oil. When I check the level its usually a goldish brown after a week. My last two oil changes when I checked after 2 days its already a pretty dark brown.
Has anyone had this problem? Thanks for your point of views.
Old Jul 17, 2007 | 05:13 PM
Nubo's Avatar
Lubricious
RX-8 oil change leaves about 3 quarts of old oil in the system. So your 3/4 quart "flush" still leaves a significant quantity of old oil in the system. It mixes with the new oil, and Voila!, dark oil.
Old Jul 17, 2007 | 05:18 PM
Go48's Avatar
Two days is about right. Keep in mind that when you drain the oil, only about 50-60% (maybe 70% if you do it right) of the old oil is drained. The rest stays in the oil coolers and oil lines. Total dry capacity is about 7 qts. If you try real hard, you can get about 5 qts. drained, leaving 2 qts. of dirty oil in the system. It doesn't take much mixing for the oil to turn dark.
Old Jul 18, 2007 | 10:52 AM
Even with new engine/car, the oil inside gets dark as fast as a week...
Old Jul 18, 2007 | 10:55 AM
mysql101's Avatar
if you perform oil changes as mazda specifies in the manual (every other fill up), it should not turn dark.
reading comprehension FTW!
Old Jul 18, 2007 | 11:37 AM
imrtommy's Avatar
Oh, damn. Thanks a lot guys.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
