Brake Pads & Suspension
Old Jul 13, 2007 | 03:02 PM
A.Mair's Avatar
Im going to be getting some new brake pads and suspension when i get my new wheels and tires (pretty soon) so i was originally thinking of the Mazdaspeed brake pads and suspension. But i did a search and a few people said that they are over priced and you can get better for cheaper. Is this the same for the suspension too?
If so does anyone have any recommendations about the same price point or less?
Old Jul 13, 2007 | 03:14 PM
SouthFL's Avatar
Hawk Performance Ceramic pads are a good, low dust, low noise performance pad for street driving. Can't go wrong with them. Tirerack has 'em.
Suspension- what are you looking to get out of it? Looks, performance, track time?
Old Jul 13, 2007 | 03:20 PM
A.Mair's Avatar
those hawk ones are a really good price.
Suspension yeah performance and looks really i dont go to the track
Old Jul 13, 2007 | 11:01 PM
BlueRenesis82's Avatar
Registered Tracker
if you are not planning on doing anything motorsports related, just stick with the stock suspension. Its great and cheap
Old Jul 14, 2007 | 01:02 PM
A.Mair's Avatar
really, even if i was going to lower it a bit?
Old Jul 14, 2007 | 02:32 PM
SouthFL's Avatar
Lowering a bit requres lowering springs. Try searching as to popular spring choices for an aesthetically pleasing stance which pair up well with stock dampers. Going too low goes beyond proper suspension geometry (not good). Going with too much spring rate will greatly shorten the life of the stock damper. One could always go with aftermarket dampers as well. Either way, search around and good luck!
Old Jul 15, 2007 | 01:11 AM
Registered Tracker
i guess I don't understand why you would alter the stock suspension for no reason, other than to look good
Old Jul 15, 2007 | 01:18 AM
paulmasoner's Avatar
Asshole for hire
get some (insert company name here) brakes!!
+1
Old Jul 15, 2007 | 02:47 AM
A.Mair's Avatar
well ive never done any modifications to any car, this is my first car and i just wanted advice, i really have not got a clue on anything like lowering the car etc. i was just looking for some advice
Old Jul 15, 2007 | 02:58 AM
the advice would be read around a bit..
lots of info on both brake pads, and springs..
read more save more..
good luck..
Old Jul 15, 2007 | 03:04 AM
Cody Red's Avatar
always filling [the c]up
tein s-techs are more of a 'dress-up' spring set up. 1.7 drop in front and .7 in rear. i'm sure there are lower ones or something but i know for sure Hawk pads are great but they're not much different from stock pads unless you get the hps plus, which are track pads i believe, but generate a lot more brake dust and possibly more noise.
Old Jul 15, 2007 | 07:52 AM
Registered Tracker
keep it stock
Old Jul 15, 2007 | 08:06 AM
SouthFL's Avatar
There's no hps plus
The Hawk HPS is a performance street/autocross pad.
The Hawk HP Plus is a trackable compound that can be driven on the street.
The Hawk Performance Ceramic is a compound which gives HPS type performance with little dust or noise.
As for S-Techs, coming from the WRX community, the S-Tech also was more of a show/look spring which dropped the car too low (beyond proper performance range). The H-techs are a less extreme alternative which paired well with stock dampers. Is this the case with the RX8?
Old Jul 15, 2007 | 09:38 AM
imput1234's Avatar
I ♥ Drifting!!!
Stick with OEM pads, our cars stop very quickly, I don't know why people change the breaks for just street driving however tracking/autoxing is a different story. As far as suspension goes, the stock car is among the best, improving yourself as a driver will be the biggest and more satisfactory modification IMO.
Old Jul 15, 2007 | 11:27 AM
HCTR154's Avatar
I recently replaced my worn front pads with a set of Wagner's Thermo Quiet pads. They were actually cheaper than the off brand or OEM pads at O'Reilly's.
RX 8 has superb brakes from the factory, take advantage of them and spend the money saved on some lowering springs.
Old Jul 15, 2007 | 11:40 AM
supergoat's Avatar
I don't "smell good".
I replaced my stock pads with Hawk HPS pads recently and love them. I agree that the stock brakes are awsome from the factory but I needed new pads and decided to do a small upgrade while doing them. I'll keep getting Hawk. Great response and just "that" much better than stock.
So +1 for Hawk.
Old Jul 15, 2007 | 12:02 PM
Nopstnz's Avatar
If you were going to drop it I would recommend the mazdaspeed shock/spring setup. Just enough drop but not too much IMO.
Old Jul 15, 2007 | 04:26 PM
A.Mair's Avatar
i think i am going to go for the hawk for sure, just going to read round a bit more for the supsension.
A few ppl have mentioned that our stick pads are good but my car doesnt seem to want to stop sometimes, i wouldnt say that mine are really that sharp. I bought it used so dont know how the previous owner cared for it
Old Jul 15, 2007 | 05:27 PM
Fanman's Avatar
I have the Hawks & they work well, but the best investment for a better change is o get yourself some stainless steel brakelines. I swapped my stock rubber hoses out for Goodrich SS brakelines and the difference was stark. The brake pedal is much stronger & better feeling.
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
D13
Oct 1, 2015 07:55 AM
