View Full Version : Tire pressures
Mazdagirl
07-12-2007, 01:58 PM
Hi Guys,
I just purchased some Falken Azenis RT 615... They have made a HUGE difference for me! I'm now beating the 350Z guys in my class!
Anyways... I have been running PSI 30 front 28 in the rear..
I have been doing some reading and I think it should be higher?
Any thoughts?
Thanks =)
Beth
yiksing
07-13-2007, 11:07 AM
Isn't recommended pressure in the manual says 32 psi? so probably more at autox
alnielsen
07-13-2007, 01:06 PM
Maybe slightly more pressure 32-35 for those tires. Are you autocrossing? Have you been checking for how much tire roll your getting?
Mazdagirl
07-13-2007, 02:18 PM
Yes I AutoX... I have only raced on them 2 times and was running 30 front and 28 in the back...
alerx-8's
07-13-2007, 02:21 PM
im also interested on what tire pressure to run. not sur if i just keep it up the recommended level or bump it up a few.
NoRotorNoMotor
07-13-2007, 09:19 PM
Reccomended pressure in my manual (2005 GT) is 35psi all the way around.
I run at 37 evry day .... 38 for AX ... but I may try it lower next event.
Cody Red
07-13-2007, 09:21 PM
32 all around just like in the manual is fine.
i'm keeping up with the 'faster' cars with these settings.
Razz1
07-14-2007, 12:17 AM
Holy Transformer!
Mazdagirl
07-16-2007, 06:22 PM
Thanks for the input on pressures, I raised them to 32 front and 30 rear and came in first out of 4....:yesnod:
staticlag
07-16-2007, 06:25 PM
for autox with the RT 615s i have found 34-35 psi all around to be just right. These are hot pressures, so check them before each run to make sure that your heading out there with those pressures.
CosmosMpower
07-17-2007, 09:36 AM
I liked 32/30 or 34/32 on my 255/40/17 RT615's.
Derex'8
07-17-2007, 11:58 AM
31/29 on 245/40/18 SPTs :wink2:
timaf
07-18-2007, 02:21 PM
The manual is not going to help you with autocrossing or 615's. Pick a starting point, chalk the side walls and see how much roll you have.
Derex'8
07-19-2007, 05:00 PM
Hi Guys,
By how much were they beating you before 615s and by how much are you beating them now?
Mazdagirl
07-19-2007, 07:39 PM
Times usually looked like this:
Them 42.202
Me 42.213
Now I'm
Me 40.661
Them 41.518 and 41.601
I cant believe the difference......... Its either the tires or I'm getting better!!!!!! Or both!!!
Razz1
08-04-2007, 04:45 PM
Both
Silver_Surfer
08-04-2007, 06:21 PM
Why are most of you(Auto-X) guys running less pressure in the rear?
Razz1
08-08-2007, 01:01 AM
traction.
carbonRX8
08-08-2007, 01:06 AM
I cant believe the difference......... Its either the tires or I'm getting better!!!!!! Or both!!!Actually, you are gettin' worse, but the new tires are doing all they can to keep up. Balances out for the better in the end.
BTW, my tires get down right sloppy at 32. I keep them around 38.
Silver_Surfer
08-09-2007, 09:36 PM
traction.
Yeah, Duh!:crazy:
Just over thinking......
wrightcomputing
12-06-2010, 07:51 PM
When I autocross I Chalk the tires in 3 places then set the tire pressure about 40 all round and drop until I am using all the tire. Typically 40 up front and 39 at the back. When you get better you will use more of the tire because you corner quicker so you need to increase the pressure. Chalk line should be rubbed off where the tread is but not rub on the side wall. Some tires have a little arrow to show you where the best line is. Best thing to do is trail and error if you change is by about + or - 2 psi you should really feel the difference in the cars handling.
