raceus
07-10-2007, 06:02 PM
J've got a porblem with start hot engine. at morning when engine is cold, it start normal...but when engine temp. is above 90 its hard to start
Sorry about my English:D
View Full Version : Problem with start hot engine raceus 07-10-2007, 06:02 PM J've got a porblem with start hot engine. at morning when engine is cold, it start normal...but when engine temp. is above 90 its hard to start Sorry about my English:D XRX8X 07-10-2007, 06:11 PM auto or 6sp.last flash from dealer,last tsbs done???miles on car?more info please!when did you buy it?what dealership?how many miles?fluid levels?bad plugs? staticlag 07-11-2007, 02:04 AM Is your battery okay? Maybe new spark plugs also savedsol 07-11-2007, 07:59 AM Happened to me but I never got a hot day to start it. Mine would not start off if I would drive to a store and then run in and run out. Took 20 min for the engine to cool and gain compression. In the end it was dying motor but the initial fix that worked was getting the updated starter. This is what you want to see if it was done... http://www.finishlineperformance.com/rx8/docs/pdf/01-048-06-1691.pdf raceus 07-11-2007, 10:25 AM Bought in germany 2005, 20000km (j've don't know how many miles it is), In last 2 months i changed spark plugs, oil, filters, flash, ECCENTRIC SHAFT POSITION SENSOR and J dont know what to do?? |
