savedsol
07-09-2007, 12:09 PM
Talking to a very well known RX-8 racing team they mentioned they run Mobil1 in their transmission. The only option I see is the 75W-90 but it's got friction modifiers for LSDs. Seems like a no-no for synchros - or am I wrong? I've used Redline and am not totally wowed. I've scoured other forums but a lot of manufacturers don't allow GL-5 (unlike the 8) in their trannies so there's not a lot of buzz.
On a side note anyone use GM Synchromesh?
savedsol
07-09-2007, 04:29 PM
MT-90. I know you've recommended the Shockproof (don't remember which weight) and Roar Racing uses MTL. Not to be a wannabe but I figure if the #1 RX-8 racing team uses Mobil1 it deserves a looksee. I emailed Mobil and they will not advise the 75W-90's use in transmissions. WTH???
yiksing
07-09-2007, 10:30 PM
I currently use the Mobil-1 SHC tranny fluid, no problems so far
savedsol
07-10-2007, 07:39 AM
Lucky you. Not sold in the States from my findings (I've heard of 5 gallon buckets here though). I'll keep searching unless someone can chime in.
EDIT: Mobil says it was discontinued (in the States maybe) and they recommend Mobil Delvac Synthetic Gear Oil 75W-90 which is also nowhere to be found - including their site.
http://www.mobil.com/USA-English/Lubes/PDS/NAUSE2CVLMOMobilube_SHC_75W-90_80W-140.asp
Looking at all of those qualifications at the bottom of the above link, that must be some good stuff.
savedsol
07-10-2007, 12:43 PM
Well funk it, I just ordered some Motul Motylgear 75W-90. Will report back in a separate thread. See red bold below for reason I chose it over Motul Gear 300...
-MOTUL MOTYLGEAR 75w-90
-Specifically recommended for gearboxes that are hard to shift.
-All types of cars: Circuit, Group A, Rallye and 4WD
-100% Synthetic - Ester based.
-Extreme pressure, anti-wear, anti-corrosion and anti-foam.
-For all gearboxes and hypoid rear axles without limited slip systems.
-Suitable for all types of fuel: leaded and unleaded gasoline, gasoil, LPG.
-Performance Standards: API GL4 and GL5 / MIL-L-2105D
-Very high lubricating power which decreases friction and wear.
-Very easy gear shifting. Thermal stability under high temperature.
-Available in 1 Liter containers.
