18x9.5 tire size
Old Jul 8, 2007 | 08:58 AM
twisted8's Avatar
18x9.5 tire size
I'm thinking about getting a set of Sport Max 006 wheels. 18x8.5 front, 18x9.5 rear 35mm offset.
1. Would these fit with that offset?
2. What size tires should I get? I don't want want thin tires. I like the comfort of the stock tires. My car is not lowered but i'd like to lower it an inch or so in the future
thanks!
Old Jul 8, 2007 | 09:49 AM
I8U's Avatar
I8U
Man, screw the staggered setup! Go 18x9.5 45mm offset on all the corners and run 275/35's or even 285/30's!!!
Old Jul 8, 2007 | 10:15 AM
twisted8's Avatar
they only come in 35mm offset
Old Jul 8, 2007 | 02:10 PM
DarkBrew's Avatar
Extraordinary Engineering
By thin do you mean lower profile?
You need to keep your sidewalls at roughly 100mm (like stock 101.25)
So 275-35-18 gives you 96.25. Your speedo will over read by a few percent.
265-40-18 gives you 106 Your speedo will under read by a few percent.
255-40-18 give you 102
245-40-18 gives you 98
Old Jul 8, 2007 | 02:44 PM
I8U's Avatar
I8U
You can re-calibrate your speedo.
Old Jul 8, 2007 | 02:55 PM
scsi's Avatar
stagger sucks you can fit 18x9.5 +35 all around but its a very aggressive fitment and youll have to roll fenders and may still rub. 275/35 may not fit with that offset, but on the 9.5s you could run 265 or maybe even 255
Old Jul 9, 2007 | 09:06 AM
twisted8's Avatar
thanks for the info! yeah by thin i mean the profile. I don't want a lower profile than stock.
255-40-18 seems to have the most options available.
for 8.5 in the front 235-40-18 would be fine, right?
Old Jul 9, 2007 | 01:27 PM
scsi's Avatar
well, the profile is actually a percentage of the width. since you're going with a wider tire, you may or may not have to go lower than 40. just be sure to check the overall diameter of the tire is about the same as stock
Old Jul 9, 2007 | 02:18 PM
you want 255/35-18 and it will fit on both sizes, or you could run the narrower size on front as you suggested
depending on the actual brand/model tire though 9.5 +35 will be close to the rear fender lip with a 255, maybe even rub ... it just depends
Old Jul 9, 2007 | 02:34 PM
VASasha's Avatar
So is +45 the best offset for 18x9.5 to ensure no rubbing?
Old Jul 9, 2007 | 02:40 PM
yes, 9.5 +45 fully clears inside and out for anything up to 275, 285s supposedly clear but I don't have enough specifics to recommend it for any and all tires that size
Old Jul 9, 2007 | 06:46 PM
MazdaJeff's Avatar
Thanks for confirming.
Old Jul 16, 2007 | 12:21 PM
type59's Avatar
mrjackwong
is a 2% difference in diameter bad? besides the speedo being off.
Old Jul 16, 2007 | 12:32 PM
NgoRX8's Avatar
the only issue with tire diameter is the speedometer being off.
yurcivicsux
192
Sep 12, 2017 10:54 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
