RNE515
07-08-2007, 12:57 AM
Hi guys,
I have done a stack of reading on here and all over the place and just want to make I am doing this right before I do something stupid that can be avoided! some advice from the audiophiles would be much appreciated! :bowdown:
I finally have all my stuff and have spent the last two weekends dynamatting and laying the cabling. I am finally at the final stages :wallbash:
I have a 500/1 which will power a W6v2...my question is this...
The amp has high level inputs but only RCA inputs. So, my thought was to tap the rear (left or right) speaker, after the amp, and solder on RCA plugs to then connect to the amp.
Is this ok? can I use 16GA speaker wire from the tapped rear to the amp?
Thanks in advance guys!! much appreciated.
Also, I must say with out the DIY's on here this would have been crazy...thanks to all that went through the pain and contributed!!
Maz
Maz
