AVELETRONIC install question
Old Jul 7, 2007 | 09:50 PM
DDJFLW's Avatar
I have a Nav Lite...used...on the box itself what are the yellow, blue and black wires for? I know the red is main power lead but what about the others. I need to know a.s.a.p
Old Jul 7, 2007 | 09:58 PM
WikkedOne's Avatar
Deals on wheels
You have a what? an Avelectronic nav lite? what is that? is it a GPS? can you find us the website?
Old Jul 7, 2007 | 10:09 PM
DDJFLW's Avatar
Its a kit that allows video on the nav screen.
http://www.avelectronic.com/products.htm
Old Jul 7, 2007 | 10:30 PM
WikkedOne's Avatar
Deals on wheels
well i'm going to guess that the black is a ground
so then the other 2 are probably the video out. the 2 Rca's on the case are probably the inputs - although i am just just guessing
Old Jul 8, 2007 | 12:56 AM
DDJFLW's Avatar
Nevermind i figured it out...yellow = ebrake so i just have to ground that. Works now. Dont know what the blue wire is for but obviously i dont need it.
Old Jul 8, 2007 | 10:05 AM
DDJFLW's Avatar
Who knows what the blue wire is for...now its buggin me just not knowing ;\
Old Jul 8, 2007 | 11:12 AM
WikkedOne's Avatar
Deals on wheels
OOoo i bet its the reverse line so it knows when to turn on the reverse camera. You have to wire that to the + on the reverse lights in the trunk, or find the wire that goes back there in the wire harness under the dash on the drivers side
Old Jul 8, 2007 | 07:13 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
I haven't done anything with mine in over a year but WikkedOne is correct. The blue wire was for connecting to the reverse line, so that the nav lite will automatically switch your display to the rear cam input when you shift into reverse gear. If you are not planning on installing a camera though, you could also just ground the blue wire to a switch and connect something else (XBox, DVR, whatever) to that rear cam input instead of a camera...though I never tried that since I wanted a camera.
On my setup, I had the reverse cam going to both the nav lite input as well as one of my DVD player's inputs, so I could switch to the rear cam even when the car isn't reversing by using the DVD player's remote control.
Old Jul 8, 2007 | 11:21 PM
DDJFLW's Avatar
See thats what im planning on doing...just hooking up the reverse cam straight to the DVD player...since it has the inputs, might aswell use them.
Old Jul 9, 2007 | 08:59 AM
foo77's Avatar
4th batch : Apr 03'
don't know if this help:
mr. GrandGame
Sep 9, 2025 10:41 PM
Pelleilee
Sep 29, 2019 10:07 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
dancingdan42
Aug 19, 2015 09:29 AM
MolecularConcept
Aug 5, 2015 04:43 PM
