blipblip
06-28-2007, 03:00 PM
Will 17x9.0 35ET Enkei RPF1 with 255/40/17 TOYO RA-1 work without rubbing issues? Will it clear OEM brake (from 06 6spd) ?
I plan to use Bilstein PSS9 coil over susp.
View Full Version : Track wheel question blipblip 06-28-2007, 03:00 PM Will 17x9.0 35ET Enkei RPF1 with 255/40/17 TOYO RA-1 work without rubbing issues? Will it clear OEM brake (from 06 6spd) ? I plan to use Bilstein PSS9 coil over susp. eviltwinkie 06-28-2007, 03:08 PM Yes... blipblip 06-28-2007, 03:18 PM Additional question: Found goodwin racing has the same size wheel with 45 ET. Thus, the question is, which one will be better? I assume with a 35 ET the tires will be further apart (+10mm) thus having wider track? eviltwinkie 06-28-2007, 03:31 PM The 45 is what is most commonly used, I would stick to that as its a proven setup. TeamRX8 06-28-2007, 03:58 PM 9.0 +35 with a 255 may rub the rear lip, it will be very close, well IMO it will rub slightly +45 is no problem though, I ran this in 9.5 with wider tires than yours without issue Red Devil 06-28-2007, 04:45 PM Will 17x9.0 35ET Enkei RPF1 with 255/40/17 TOYO RA-1 work without rubbing issues? Will it clear OEM brake (from 06 6spd) ? I plan to use Bilstein PSS9 coil over susp. Spring rates are a bit funky on those for the RX-8. The rears are stiffer than the fronts. Just a heads-up. blipblip 06-28-2007, 04:50 PM Spring rates are a bit funky on those for the RX-8. The rears are stiffer than the fronts. Just a heads-up. What's your driving impression on those? blipblip 06-28-2007, 04:51 PM 9.0 +35 with a 255 may rub the rear lip, it will be very close, well IMO it will rub slightly +45 is no problem though, I ran this in 9.5 with wider tires than yours without issue Thanks. Will go with the goodwin racing version then... Red Devil 06-28-2007, 04:58 PM What's your driving impression on those? I looked into them, but didn't purchase them...so I can't offer anything tangible, just what I found out. If you do a search, you'll see I posted about it a while back inquiring why they would have done that. http://www.rx8club.com/showthread.php?t=92769&highlight=PSS9 blipblip 06-28-2007, 05:07 PM I looked into them, but didn't purchase them...so I can't offer anything tangible, just what I found out. If you do a search, you'll see I posted about it a while back inquiring why they would have done that. http://www.rx8club.com/showthread.php?t=92769&highlight=PSS9 I read your thread. The PSS9 was in my plan because it worked well on a e46 m3. Guess for rx8 its a different story... Anybody tried those? What other option should I consider? mac11 06-28-2007, 05:10 PM Read your thread. The PSS9 was in my plan because it worked well on a e46 m3. Guess for rx8 its a different story... Anybody tried those? What other option should I consider? I think what was listed in his thread as things he considered is a good place to start. I have also seen one of the vendors around here mention Tein basics as one of the best bang for the buck coilovers around - i dont know how much money and adjustability are a factor to you. What will you be using the car for? That could narrow down what you are looking for. mac11 06-28-2007, 05:10 PM Read your thread. The PSS9 was in my plan because it worked well on a e46 m3. Guess for rx8 its a different story... Anybody tried those? What other option should I consider? I think what was listed in his thread as things he considered is a good place to start. I have also seen one of the vendors around here mention Tein basics as one of the best bang for the buck coilovers around - i dont know how much money and adjustability are a factor to you. What will you be using the car for? That could narrow down what you are looking for. Will this be a daily driven + HPDE car or an all out track only setup? and road course> autoX, time attack? etc... blipblip 06-28-2007, 05:20 PM NASA time trial TTD class Red Devil 06-28-2007, 05:41 PM It appears for TTD that for adjustable dampers like the PSS9, or Tein Flex, etc...that you'll take a 10 point penalty. While off the top of my head you'll only get a 5 point penalty for a non-adjustable. You're also going to take point penalties for running above a 245mm tire, and a few more for the 100+ tread rating. Before you make a decision, I'd play around with the 19 points and get confirmation from NASA. You don't want to make a mistake and spend money on a combo that will get you moved to C. Was actually playing around with this yesterday for TTD after seeing your other thread as I've thought about it from time to time. blipblip 06-28-2007, 06:00 PM It appears for TTD that for adjustable dampers like the PSS9, or Tein Flex, etc...that you'll take a 10 point penalty. While off the top of my head you'll only get a 5 point penalty for a non-adjustable. You're also going to take point penalties for running above a 245mm tire, and a few more for the 100+ tread rating. Before you make a decision, I'd play around with the 19 points and get confirmation from NASA. You don't want to make a mistake and spend money on a combo that will get you moved to C. Was actually playing around with this yesterday for TTD after seeing your other thread as I've thought about it from time to time. Thanks for the heads up. Non of these will be finalized. It is in the planning stage. I'll bring my plan to NASA TT director before spending money. blipblip 06-28-2007, 06:05 PM So far, my first draft of plan: TOYO RA-1/ NITTO NT-01 +5pts 255 width tires +1pts Coilover suspension +10pts F&R sway bar +2pts Total: 18pts mac11 06-28-2007, 09:46 PM don't forget with the adjustable shocks you still have to take the penalty +2 points for aftermarket springs as well. That would put you at +20 and in C-class. Run 245 width tires and you stay in TTD. You may also want to calc out just how much wider the track of the car will be with 9" wide wheels and a +35 offset. There is a penalty for going 2" or more wider than the factory track width. blipblip 06-28-2007, 10:51 PM don't forget with the adjustable shocks you still have to take the penalty +2 points for aftermarket springs as well. That would put you at +20 and in C-class. Run 245 width tires and you stay in TTD. You may also want to calc out just how much wider the track of the car will be with 9" wide wheels and a +35 offset. There is a penalty for going 2" or more wider than the factory track width. Hmm, didn't consider the track difference. I doubt it'll be wider than 2" but will definitely look into that. At this point, I think I'll go with +45 offset. As for suspension, hmm, maybe I should go with springs+shocks......any inputs on this? mac11 06-28-2007, 11:09 PM Hmm, didn't consider the track difference. I doubt it'll be wider than 2" but will definitely look into that. At this point, I think I'll go with +45 offset. As for suspension, hmm, maybe I should go with springs+shocks......any inputs on this? Actually I am on the phone right now discussing what exact classification the Tein Flex should fall under. I won't have anything official until I talk to a NASA official but the thinking right now is that they should probably fall into the +3 rating. And I believe that the tein basics should have no problem being in that +3 rating. altiain 06-29-2007, 03:16 PM Actually I am on the phone right now discussing what exact classification the Tein Flex should fall under. I won't have anything official until I talk to a NASA official but the thinking right now is that they should probably fall into the +3 rating. And I believe that the tein basics should have no problem being in that +3 rating. Wouldn't the sum total of the Flex or Basics be +5? +3 for non-OEM shocks, and +2 for non-OEM spring rates. mac11 06-29-2007, 03:35 PM Wouldn't the sum total of the Flex or Basics be +5? +3 for non-OEM shocks, and +2 for non-OEM spring rates. That is what we are thinking now. The question was if they would fall into of the +10 - Non-OEM shcocks/struts/dampers with an external reservoir or more than two ranges of adjustment (must still take points for springs below). The tein flex having the rebound/compression adjustment was what was in question but I think we settled on that since it is only a single adjustment for rebound & compression simultaniously it should be covered by the rule you are referring to and I was mistaken. blipblip 06-29-2007, 03:44 PM From NASA TT Rules 1) Non-OEM shocks/struts/dampers with an external reservoir or more than two ranges of adjustment +10 (example: compression (bump) and both high & low rebound adjustments)(must still take points for springs below). Confusing... Using Bilstein PSS9 as an example, it only offers compression and rebound settings adjustment. Does it mean that it is a 2 'range' adjustment? If that is the case, then the common available coil over system to amateurs should all be considered a +7 (then you add +2 for springs, which total out +9), rather than the +12 total as I originally thought. From where I came from, we usually call it 2 'way' adjustable shocks....:Wconfused mac11 06-29-2007, 03:56 PM Confusing... Using Bilstein PSS9 as an example, it only offers compression and rebound settings adjustment. Does it mean that it is a 2 'range' adjustment? If that is the case, then the common available coil over system to amateurs should all be considered a +7 (then you add +2 for springs, which total out +9), rather than the +12 total as I originally thought. From where I came from, we usually call it 2 'way' adjustable shocks....:Wconfused +7? non-OEM shocks/struts/dampers with a retail price of greater than $600 per unit (2400 total) or $750 each if sold only as a coilover with spring included ($3000 total). Also "piggyback" external reservoir shocks/coilovers/dampers with a retail price of less than $1050 per unit ($4200 total) - must still take additional points for the springs below +7 I don't agree that the PSS9s and other commonly available coilovers would fall into thise rule. The one that comes to mind that WOULd is the KW variant 3. what originally made me think the tein flex's would fall under the +10 rule is the combination of haivng rebound, compression and ride height adjustability. 3 that technically is 3 ranges of adjustment. But then with rebound and compression being controlled by a single adjustment i don't thik it would fall under that rule. blipblip 06-29-2007, 04:11 PM +7? 2) Non-OEM shocks/struts/dampers with a retail price of greater than $600 per unit ($2400 total) or $750 each if sold only as a coilover with spring included ($3000 total). Also “Piggyback” external reservoir shocks/coilovers/dampers with a retail price of less than $1050 per unit ($4200 total)—must still take additional points for the springs below +7 3) Non-OEM or modified/re-valved shocks/struts/dampers +3 (all others)(springs not included) Mistake by me. Miss read the lines. I just sent the national TT director an email looking for clarification. Let's see what he has to say. altiain 06-29-2007, 04:12 PM I think you guys are misreading the rule: From NASA TT Rules 1) Non-OEM shocks/struts/dampers with an external reservoir or more than two ranges of adjustment +10 (example: compression (bump) and both high & low rebound adjustments)(must still take points for springs below). This rule is written regarding dampers and dampers only. Notice that the only adjustment examples are variations of damping adjustment - compression, high speed rebound, and low speed rebound. Spring perch height is external to the damper mechanism, and is not normally considered a damper adjustment. Disclaimer: I don't normally play with NASA, so maybe they interpret things a little differently, but I've never heard of spring perch height included when describing the number of adjustment ranges on a damper. mac11 06-29-2007, 04:13 PM I just sent the national TT director an email looking for clarification. Let's see what he has to say. I was planning on asking the regional guy when I attended a NASA event comming up in the next month or so but this should be the authority on the matter. mac11 06-29-2007, 04:16 PM I think you guys are misreading the rule: This rule is written regarding dampers and dampers only. Notice that the only adjustment examples are variations of damping adjustment - compression, high speed rebound, and low speed rebound. Spring perch height is external to the damper mechanism, and is not normally considered a damper adjustment. Disclaimer: I don't normally play with NASA, so maybe they interpret things a little differently, but I've never heard of spring perch height included when describing the number of adjustment ranges on a damper. You may - and probably are - entirely corerct in that i am misinterpreting the rule. I also am just starting to read these rules. I was simply trying to error on the side of caution. I wouldn't want to show up with Tein Flex's thinking I had a +19pt car and just stay in TTD and be asessed the extra 7 points and now be on the very low end of a TTC car. blipblip 06-29-2007, 04:18 PM Just a thought, I think they (NASA) could use some good technical writer... mac11 06-29-2007, 04:27 PM I just posed the question on the NASA forums. Lets see what the guys with the experience have to say. http://www.nasaforums.com/viewtopic.php?p=102183#102183 blipblip 06-29-2007, 04:36 PM This says it all: http://www.nasaforums.com/viewtopic.php?t=12774&highlight=coilover blipblip 06-29-2007, 04:41 PM So, let me try this again: TOYO RA-1/ NITTO NT-01 +5pts 255 width tires +1pts Coilover suspension +3pts Springs +2pts F&R sway bar +2pts Total: 13pts I guess then I can go with Hoosiers/V710s and still stays in TTD? mac11 06-29-2007, 04:46 PM Yes. Good. Well....good for those with Tein Flex's and equivilant. blipblip 06-29-2007, 04:58 PM Cost: Wheels: $1,076.00 Tires: $648.00 Coilover (Tein Mono Flex): $1,880.00 RB F&R Sway + Links: $388.00 Installation, shipping and installation (estimate): $600.00 Total: $4,592.00 Not as bad as I thought........ TeamRX8 06-29-2007, 05:54 PM better swaybars and there's no need for the endlinks http://www.rx8club.com/showthread.php?t=109096 edit: maybe not for you if they give points for adjustable bars mac11 06-30-2007, 01:17 AM better swaybars and there's no need for the endlinks http://www.rx8club.com/showthread.php?t=109096 edit: maybe not for you if they give points for adjustable bars i dont think there is a difference in the points asessed for sway bars being adjustable or not. If people have been snapping end links with the racing beat bars then why would these hold up with no upgraded endlinks? and conversly if these hold up without the upgraded endlinks why wouldn't the setup with racing beat bars hold up? Spin9k 06-30-2007, 08:36 AM The simple answer to why most people break endlinks is that they mess up and install the rear bar upside down. Now go for a ride...Ding..Ding..Ding... You are a winner! ...and now have broken endlinks ... :) very simple! mac11 06-30-2007, 03:40 PM The problem with that answer is that racing beat recommends to upgrade the FRONT endlinks. Spin9k 06-30-2007, 06:09 PM I've not heard of an OEM front link breaking given everything was installed 100% correctly. Perhaps someone has some experience if there's has ever gone bad? Seems most difficulties of this type are cockpit error, not true end link failure. There's nothing wrong with making them more heavy duty, but if the end result is the same...it's just personal choice and a little revenue for RB.. eviltwinkie 06-30-2007, 11:39 PM The simple answer to why most people break endlinks is that they mess up and install the rear bar upside down. Now go for a ride...Ding..Ding..Ding... You are a winner! ...and now have broken endlinks ... :) very simple! Yep...never heard of the stock failing...I'm sportin the RB sways too... blipblip 07-02-2007, 06:13 PM better swaybars and there's no need for the endlinks http://www.rx8club.com/showthread.php?t=109096 edit: maybe not for you if they give points for adjustable bars Good specs and good price. Do you think it'll make the car too tail happy for track? TeamRX8 07-02-2007, 07:19 PM that would depend on any variety of factors, but my experience is that it's unlikely since both the front & rear bars are adjustable. It gives you quite a bit of balance range. blipblip 07-03-2007, 12:17 AM that would depend on any variety of factors, but my experience is that it's unlikely since both the front & rear bars are adjustable. It gives you quite a bit of balance range. Knew it was going to be hard to quantify. I guess I'll have to do some test 'n' tune |
