Will these wheels fit on my RX-8?
Old Jun 27, 2007 | 02:48 PM
Stake81's Avatar
Hi guys, I just got my dream RX-8. Im so glad and amazed to see that this car has such a following. I can tell that this site is going to be a big help already! I wanted to get some cheap rims (eventually) to put my snow tires on... so i have two questions.
1. Will these wheels fit on the car? 18x8, 5x4.5 bolt pattern, offset ET20
2. IS the TPMS absolutely necessary? Or can i go without it and the only thing i have to worry about is the annoying warning light?
Thank you for your help.
- Stake
Old Jun 27, 2007 | 02:55 PM
scsi's Avatar
congrats on your purchase. +20 offset is a bit low, i have never heard of anyone going that low, but most people up the width as well. i dont know about that bolt pattern, im just too lazy to convert it, but ours is 5x114.3 so if those are equivalent then theyr good in that sense
tpms is not absolutely necessary for our car. most people here dont use them on their aftermarket wheels
gL
Old Jun 27, 2007 | 03:04 PM
NgoRX8's Avatar
the bolt pattern matches
offset wise, you probably might rubb in the front. how bad the rubb will depend on your tire size. the rear should be fine, although there's a chance it could rub if depending on tire size as well, which could be fixed with a slight fender roll.
my suggestion, find wheels with higher offsets.
Old Jun 28, 2007 | 09:36 AM
Stake81's Avatar
So... If im getting this right... the lower offset is pushing the wheels out more? Is that right? Ohhh... and I would be putting the stock size tires on them P225/45R18. I dont understand this offset thing at all.
Old Jun 28, 2007 | 05:37 PM
lazi's Avatar
drivelinestore.com
let me know if your interested in some rims. i'll see what i can help you out with =) so if your gonna run stock tires. it would be 18x8 your looking at
WingleBeast
22
May 23, 2016 09:22 PM
Kahl
Aug 20, 2015 11:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Brandonien
Jul 30, 2015 12:33 PM
