Making hand brake more responsive?
Old Jun 27, 2007 | 01:48 AM
xbeatxdownx's Avatar
How do you change the responsiveness of the hand brake? Or is there a way, is the better question.
Old Jun 27, 2007 | 01:55 AM
adjust it to be tighter, get a service manual
Old Jun 27, 2007 | 02:29 AM
636's Avatar
636
Rice Police
wait a second...why do you want more "responsiveness" on the hand brake? Dont tell me you're pulling that thing while driving are you? >_>
Old Jun 27, 2007 | 02:37 AM
Other then spending money on a manual. Have any help? AKA diy.
Old Jun 27, 2007 | 02:39 AM
No for parking on steep hills
puff's Avatar
i find it very hard to get the rear to slide out, hand brake turns drift style, with this car!
haha, i've adjusted mine tighter but it's still not very firm.
this handbrake was designed to be used this way: apply foot brake, pull hand brake. then its pretty solid enough
Old Jun 27, 2007 | 02:41 AM
puff's Avatar
on a steep hill, just leave the car in gear. that's your safest bet.
Old Jun 27, 2007 | 03:06 AM
how about figuring it out and writing one, otherwise learn how to search and explore
Old Jun 27, 2007 | 07:53 AM
Aero8's Avatar
pm'd
Old Jun 27, 2007 | 08:20 AM
man, go search. Mr. 5 posts
Old Jun 27, 2007 | 05:03 PM
O RLY! Thanks for all the help from you sir and for noticing that I just started to post. There was some point when you had 5 posts. Anyways thanks for any of the help. I'll check it out myself just figured I would ask for any help.
Old Jun 27, 2007 | 05:05 PM
SE3PSynergy's Avatar
Has a headache.
Ya Rly... you want it more responsive? Pull the thing up like a man. That works
Old Jun 27, 2007 | 10:50 PM
make the brake lever longer.
Old Jun 28, 2007 | 06:19 PM
midlife crisis's Avatar
Thumbs down Don't use the leave it in gear method
This car has almost NO engine braking. Use the parking brake on any incline. I live in one of the flattest areas in the world and even in parking lots the "leave it in gear" method does not work.
Old Jun 28, 2007 | 09:56 PM
diabolical1's Avatar
i'm the undead
leaving it in gear does not always work. for the 2 weeks or so that it took for me to get the rearward cables, my Rx-7 would roll while in gear on a slight incline. it scared the **** out of me the first time i parked the car and came back out to find it in a notabbly different spot. actually, now that i think about it, my MR2 actually rolled out of my cousin's driveway and into the street. his neighbor rang the bell to ask about the car in the street and that was how we found out about it.
Old Jun 28, 2007 | 10:04 PM
stickmantijuana's Avatar
Unregistered User
leave it in 5th or 6th gear, not 1st.
Old Jun 28, 2007 | 11:07 PM
i'm the undead
noted. thanks. if i ever need to do that again, i'll try to remember that. what's the reasonong behind that? i would have thought first or reverse would have been the best choices.
Old Jun 29, 2007 | 04:00 AM
8 Maniac's Avatar
Senior Member
When you're driving, is it easier to start from a stop in 1st gear or 6th gear?
Old Jun 29, 2007 | 09:41 AM
VASasha's Avatar
sometimes the obvious things that make sense, don't
Old Jun 29, 2007 | 10:41 AM
8is>enuff's Avatar
Bland
That's the opposite of everything I've ever heard or read. Engine braking (I guess driveline resistance in this case) is much more effective at higher rpms. Leaving it in first causes the tranny to turn the engine over more, leading to higher resistance.
Leave it in first or reverse, whichever is the opposite direction of travel. If you're really worried about it there are ways to make sure your car doesn't become a runaway in the event of handbrake failure, learn the direction to turn your wheel while parked on a hill - http://www.google.com/search?hl=en&r...a+hill+in+gear
Old Jun 29, 2007 | 10:46 AM
8is>enuff's Avatar
Bland
Even better -
From Standardshift.com
Parking Brake
A habit that one needs to get used to is always to set the parking brake when parking, especially on hills. Unlike automatics, there is no locked parking position with a manual transmission, only the internal friction of the non-running motor. Make sure you set the parking brake first and let up on the brakes to make sure it is engaged fully, then leave the gearshift in reverse or 1st.
http://www.standardshift.com/faq.html
Old Jun 29, 2007 | 12:00 PM
MrSuicideDoor's Avatar
clutch burner
i think the op was asking for drifting purposes
Old Jun 29, 2007 | 12:10 PM
alnielsen's Avatar
You need to read the posts before making statements.
Old Jun 29, 2007 | 06:02 PM
I really dont like how hard I have to pull it to get it to react. Thats why I started this thread. For parking and locking up the back wheels, to make tighter turns and all. Havent gotten around to tinkering with the brake yet but I'll post a how to when Im done.
Old Jun 30, 2007 | 02:57 AM
weight room..
buff up..
