Slippage at the slightest hint of dampness
Old Jun 26, 2007 | 03:14 PM
delhi's Avatar
Grand Chancellor
I noticed that my 06 GT (stock) tends to spin the rear tires fairly easily on wet roads. DSC & TSC are on. Stock Dunlop's pressure is 32psi stock as well. Any thoughts? These days I have to feather the gas pedal to minimise rear wheel spin. Geez... and I thought it has low torque.
Old Jun 26, 2007 | 03:33 PM
Wilson's Avatar
Peeping over the fence
Get some good tires and you will understand how bad the stock tires are.
Old Jun 26, 2007 | 03:46 PM
eviltwinkie's Avatar
Replace OEM's with a real set of tires...
Old Jun 26, 2007 | 03:55 PM
LionZoo's Avatar
road warrior
The Dunlops, while good in the dry and pretty civil, is not the greatest wet tire. However, mine aren't that twitchy in the rain. How long have you had the tires?
Old Jun 26, 2007 | 04:13 PM
Astral's Avatar
Purveyor of fine bass
Mine aren't as bad in the wet either... predictably slippery, but better than some of the crap OEMs I had.
Old Jun 26, 2007 | 04:56 PM
SouthFL's Avatar
Modulate throttle.
Old Jun 26, 2007 | 07:45 PM
BlueRenesis82's Avatar
Registered Tracker
get better tires. OEM tires are pretty much overpriced garbage
Old Jun 27, 2007 | 08:19 AM
CosmosMpower's Avatar
1935 lbs. FTW!
Get an alignment and dial in some rear camber and toe in
Old Jun 27, 2007 | 09:05 AM
adding rear camber will only reduce the contact area and make them spin more
Old Jun 27, 2007 | 09:23 AM
Yeah but you'll pWn teh tw1stys!! Hah
Old Jun 28, 2007 | 06:38 AM
SouthFL's Avatar
delhi's coming from an AWD, turbo lagged Saab 9-2x (you have to really rev to get going out of 1st). comparatively, the RX8 has an acute throttle response. i found this throttle response rather twitchy at first (especially at the track), but one's right foot and brain adjusts accordingly.
stock dunlops are not bad either.
Mxttz0r
Jul 5, 2019 03:19 AM
Paul_Y
Sep 21, 2015 02:23 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
emailists
Mar 1, 2005 02:56 PM
Supercharger
General Automotive
16
Apr 22, 2003 12:31 PM
