delhi
06-24-2007, 10:26 PM
I'm wondering if the 8 like most cars automatically turns on the A/C when you activate the defog function. If so, how come the A/C light doesn't light up? Or should it (warranty!). Or do I need to manually turn the A/C on as well?
puch96
06-25-2007, 08:13 PM
the A/C comes on when the defog is turned on (if the outside temperature is above 32 F) or close.
It's normal behavior. Some cars have a way to turn the "auto A/C" feature off
delhi
06-26-2007, 12:47 PM
But the A/C light doesn't come on. Is my light broken? But it comes on when I manually switch on the A/C
DarkBrew
06-26-2007, 12:50 PM
The AC light only seems to indicate that the driver asked for AC. The other functions are 'hidden'...
StealthTL
06-26-2007, 01:07 PM
The computer turns it on when you sellect certain windshield/feet flows - it's even in the manual. Says the light won't show.
If you don't like it, pull the fuse marked A/C Clutch - the computer thinks it is still working, but it ain't.
S
delhi
06-26-2007, 04:10 PM
OK i read the manual thrice.... i must've somehow dozed off in that section.
The AC won't come on if you put the selector into "full face" mode. That's what I normally use on those "bizzarre" occasions when want the heat on but not the air conditioning. :shrug:
