"Loose" Fuel Cap
Old Jun 20, 2007 | 03:11 PM
Subdivisions's Avatar
"Loose" Fuel Cap
I have a recurring gas cap problem that is really starting to **** me off!
NO MATTER how I put the fuel cap on it doesn’t feel tight.
The first few months I owned the car I kept getting a CEL.
Back and forth to dealer several times.
The dealer kept telling me “you’re not tightening the fuel cap”
I said, "It doesn't go on very tight"!
I tried a new gas cap (dealer provided OEM)
No difference
To tighten the cap, I have tried:
- tightening to one - several clicks
-a dozen clicks
-no clicks
-I have tried pushing “very hard”, “hard”, “soft”, “not pushing”
-Tightening to “just when it’s about to click”, which is a pain
The “just about to click” method worked for a while, but even then, it really wasn’t that tight … but the CEL stopped going off, so I dealt with it.
Now I’m getting a CEL again.
WTF!
It’s almost like the threads on the fuel pipe are stripped.
But how the hell would that happen, the pipe is metal and the cap is plastic.
I tried cleaning out the fuel pipe threads, but no difference.
With so many people complaining about the CEL, this has had to happen to someone else.
How did you resolve?
Old Jun 20, 2007 | 03:15 PM
Duke15's Avatar
2006 Velocity Red Mica
I had something similiar happen. I finally took my car to another dealership, explained everything the last dealership told me, and they simply replaced the cap with a new one. Viola, problem solved. The mechanic speculated that Mazda got a bad batch of gas caps made.
BTW: That was almost a year ago. Last month I received a notice of a gas cap recall (for 2004 - 2006 I think) gas caps. You might want to have them look into that. Mine didn't need replaced again.
Old Jun 20, 2007 | 03:24 PM
gently line up the cap and twist until you get 3 clicks.
If you're getting CEL from doing THAT, then you need a new cap.
Old Jun 20, 2007 | 03:25 PM
Thanks for the info.
I'm about due for an oil change, I'll have to mention the gas cap recall.
Old Jun 20, 2007 | 03:30 PM
Duke15's Avatar
Mine would come on every 780 - 800 miles after they reset the CEL. But the new cap has gone a few thousand miles without any problems.
The first dealer (and original purchase dealer) made me mad telling me I didn't know how to put a gas cap on. The mechanic was an SOB smart a** about it and needed popped in the mouth, but I settled for telling him not to be a smart a**. But that dealer sucked in so many ways anyway. They were the only Costco dealer though, which saved me a lot of money when I ordered my 2006 before they were making them.
Old Jun 20, 2007 | 03:40 PM
I had a similar situation with my dealer.
The guy was telling me "you're not tightening the gas cap correctly"
I said, "i've been driving for 22 years, I think I know how to put on a gas cap"
When I stopped having the CEL problem with the "Just about to click" method, I didn't bring up the gas cap problem again.
Other than this gas cap issue, the dealer has been stellar.
Old Jun 21, 2007 | 06:34 PM
DaveCM203's Avatar
DaveCm
I had a cell come on a couple of months ago and they found it to be the gas cap. They replaced it under warranty. So far, so good. They said that it is a common problem as there is something in the caps of the '04s that rust inside of it and cause it to leak. So, I would try to replace the cap. If you don't have warranty, it is a cheap fix.
Old Jun 22, 2007 | 10:03 AM
I wonder if I'll get a "little" better gas milage.
If the cap is not sealing correctly (loose), seems like the new recall cap would help ... less evaporation and such.
I am getting about 15 mpg with city/suburb driving.
I'll let you guys know when I go in for my next oil change next week.
Old Jun 22, 2007 | 11:13 AM
New Yorker's Avatar
Does anyone know why even the "normal"—not defective—RX-8 gas cap doesn't seem to go on tightly?
I'll click it half a dozen times or more, but when I remove it at the next fill-up, it loosens with no force whatsover—like it wasn't fully tightened. And this is normal, I think—the CEL has never come on (except during start up when all the lights come on, of course).
Does this seem odd? Every other car I've owned had a tight-fitting gas cap.
Old Jun 22, 2007 | 12:07 PM
dynamho's Avatar
There's an official recall on the old gas cap. Get it replaced.
Old Jun 22, 2007 | 12:15 PM
expo1's Avatar
He's as bad as Can
Or just buy a new one STANT GAS CAP Model 10838. It's under $10.00
Old Jun 22, 2007 | 07:01 PM
machfive's Avatar
If it aint the cap, check the threads on the filler tube, but I doubt if they are bad.
Old Jun 22, 2007 | 07:07 PM
Spinning Sushi's Avatar
I <3 Sushi
Mine did the same thing, they told me that it was a small defect in some of the RX-8's. If I remember correctly, there should also be a TSB on it.
Old Jun 22, 2007 | 07:54 PM
New Yorker's Avatar
As I said, mine seems to be loose, but with no CEL. And it's NOT in the range of cars mentioned in the TSB. I guess a "normal" RX-8 fuel cap takes almost no effort to open.
Old Jun 22, 2007 | 09:08 PM
kersh4w's Avatar
Hit & Run Magnet
my gas cap takes a bit of pressure to open. it screws on tightly.
btw, thanks for the 3 clicks = tight tip. i always did 1 click.
Old Jun 22, 2007 | 10:01 PM
ken-x8's Avatar
My original cap was like that. Going on, it felt snug like any of today's "make sure it clicks thrice" caps. I'm in the MSP-13 VIN range (even got a P0455 once), and the dealer replaced it at my last visit. The new one goes on the same. Coming off, it rotates against a spring for about a quarter of a turn, then there's resistance about like you'd expect for a cap that was actually capping.
Ken
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
