Anyone Replaced their brake pads?
Old Jun 20, 2007 | 09:30 AM
IcemanX8's Avatar
I need to replace My front pads as there is a high pitched squeel when the brakes are first applied.
Question: Can anyone advise me on the best make? ie EBC, Hawk, Centric...ect? I'd also like to go with drilled and slotted rotor eventually so I'll appreciate any advise on them too!
Thanks,
ice
Old Jun 20, 2007 | 09:34 AM
mac11's Avatar
Rotary , eh?
no.
drilled rotors are a bad idea.
what do you want for pads? how is the car being used? My track pads squeal like a pig until they are warm and are brand new.
Old Jun 20, 2007 | 09:43 AM
IcemanX8's Avatar
why are drilled/slotted rotors a bad idea>
Old Jun 20, 2007 | 09:46 AM
mac11's Avatar
Rotary , eh?
drilled rotors crack under pressure if not setup properly. It also takes away from the surface area of the rotor. You have less material to absorb the heat that is being generated.
Old Jun 20, 2007 | 09:49 AM
dmp's Avatar
dmp
RX8 and a Truk....
If you don't mind dust - Axis Ultimates are FANTASTIC pads.
Old Jun 20, 2007 | 09:51 AM
mysql101's Avatar
depends on where you buy the rotors from. cheap ebay stuff can easily crack during track use.
i like the hawk ceramic pads, got them from tirerack for about 140 shipped for all 4, no noise, low dust.
Old Jun 20, 2007 | 09:53 AM
reaper1's Avatar
There's TBS on this matter [ RX8 Service Bulletin ] . Go to finish Line Web there is something in regards to squeal noise during braking. If you take it to them with that print out they should take care of it for you.
If you do a search you will notice you're not the only one with this matter.
Old Jun 20, 2007 | 01:09 PM
cheap advice - free
decent brake fluid - $20
Hawk Ceramic brake pads - $65/axle
Searching the forum to avoid looking like the typical dumb@ss n00b - priceless
Old Jun 20, 2007 | 02:13 PM
VASasha's Avatar
Not to completely derail this thread, but is there a mileage limit to this TSB? Didn't see anything mentioned while reading it but, my car is an 04 with 30k miles on it. Any chance they would dismiss my break squeal to brake pad age?
Old Jun 20, 2007 | 02:21 PM
jskup1's Avatar
The Chief
Originally Posted by TeamRX8
cheap advice - free
Old Jun 20, 2007 | 04:28 PM
dillsrotary's Avatar
jersey fresh
ditto, get pad, quiet, low dust, and a good price.
Oh and cross drilled rotors are fine, that guy is just trying to show off his track knowledge. If you're just a normal street cruiser like most of us then drilled rotors will be perfectly fine (just get them from the proper place, like one of the forum vendors of this site.)
Old Jun 20, 2007 | 05:06 PM
sorry dood, my harsh response wasn't so mcuh directed at you as inspired by you ...
Old Jun 20, 2007 | 05:23 PM
eviltwinkie's Avatar
Which makes it that much more hilarious...
Old Jun 20, 2007 | 05:33 PM
jersey fresh
i wasn't refering to you team
Old Jun 20, 2007 | 09:33 PM
got 8's Avatar
I agree with many, the Hawk ceramic is the best.
Old Jun 20, 2007 | 10:18 PM
nor I, you
Old Jun 21, 2007 | 09:46 AM
reaper1's Avatar
I would give it a try . Take in the TSB and tell them you've had this issue for quite sometime, that you feel this is the reason for your squealing brakes. You have nothing to loose.
Old Jun 21, 2007 | 03:21 PM
RotorManiac's Avatar
Absolute Rotary Madness
I use EBC yellow stuff right now. no noise at all and low dust...
I like them more than my previous MS pads. got them for 140euros...
Old Jun 21, 2007 | 11:50 PM
Porterfield Carbon Kevlar.
Old Jun 21, 2007 | 11:57 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I have ebc in the front and I love them. No dust and no noise.
I had problems with Porterfield.
Old Jun 25, 2007 | 08:51 PM
kinchu007's Avatar
Anyone running Endless CC-X ?
Old Jun 25, 2007 | 09:53 PM
92tsiawd's Avatar
I didn't like my EBC reds that I had, they had good initial bite but they lasted a little longer than 1500 miles, that's inclusive of two LAPPING days, they would have lasted probably one Solo 1 event had I been competing. I can vouch for Project Mu's Taitan Kai pads and Hawk HP+, Project Mu had the longest life and is really quiet, whereas after the first solo event on HP+, they squeeled loud but their life seems really good, I didn't put a dent into them.
Old Jun 26, 2007 | 04:39 PM
Toly's Avatar
Carbotech. Bobcats. Warmed up.
Old Jun 26, 2007 | 07:46 PM
BlueRenesis82's Avatar
Registered Tracker
I swap brake pads and rotors quite a bit. I don't mind using some AutoZone OEM replacements for the street, I run Carbotech XP-8's for track
Old Jun 26, 2007 | 07:55 PM
shaunv74's Avatar
Power!!
Yup it's called the warranty. 4 years or 50K miles. You still have time if you act quickly.
No they won't dismiss it. They have a TSB for it and a replacement brake pad part number.
