Outter Headlight haze help
Old Jun 17, 2007 | 07:48 PM
sauceyI986's Avatar
Ok i was needed some help on this one both of my headlights on the outside has some type of haze on them or something and to me it make me anoyed just by looking at it. i was wonder should i just go ahead and replace them out or does some one have any suggestions..
Old Jun 17, 2007 | 08:21 PM
636's Avatar
636
Rice Police
um from the pics it looks like water haze. Cant you get like a blow dryer and heat it up lol. If thats pollution why dont you use meguiars plastX i heard it works good.
Is that from outside the lens or inside?
Old Jun 17, 2007 | 08:35 PM
sauceyI986's Avatar
yes it located on the outside i tried the plastic wax i had on luck.
Old Jun 17, 2007 | 08:40 PM
I tried that plastx **** and it did not work at all for minor scratches.
Old Jun 18, 2007 | 05:48 AM
Jinks's Avatar
Wanna fight about it?
I had something on my headlight that looked like that. I thought it was from water on the inside, but I rubbed it with my finger with some force and some came off. Must have been soap residue or something from when I got it washed. But I got it all off with a cloth just rubbing it.
Old Jun 18, 2007 | 09:49 PM
Targatheory's Avatar
Oh my cars lights are just like that. I used Braso and PlastX and a lot of rubbing. It shined up the lights really good, but unfortunately revealed to me that that **** is on the inside.
Old Jun 18, 2007 | 11:16 PM
MazdaManiac's Avatar
Worse yet. That haze is neither inside nor outside. It is in between the two layers of plastic that comprise the headlamp lens. It cannot be removed.
Replacing the headlamps can get expensive.
I was quoted $1200 each for the HID assemblies. I've heard they are available for as little as $600 each, but I have yet to find a dealer that will give that price.
Old Jun 21, 2007 | 03:44 PM
Chris's Avatar
Turbo Member
^I got mine replaced under warrenty so good luck... maybe you can do the same
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
